914-6 trans numbers |
gulf908 |
Nov 28 2015, 09:04 PM
Member Group: Members Posts: 122 Joined: 25-December 13 From: Sydney Member No.: 16,795 Region Association: Australia and New Zealand |
Hi,
I am looking at the trans numbers on my 5/70 US delivered 914-6. They seem to line up with the data I have from the internet. However I also have an extra '10' stamped on. Is this the indicator for a LSD ? The CofA says a 80% LSD but there is nothing driving wise to indicate that its actually working. My mechanics tell me the trans has never been apart. Cheers, Dennis. (IMG:style_emoticons/default/smile.gif) Attached image(s) |
rgalla9146 |
Nov 28 2015, 10:04 PM
Advanced Member Group: Members Posts: 4,554 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
If the trans has not been apart it should have an aluminum tag on the differential side cover specifying use of a particular Shell lubricant.
I think the serial number or type number should include HB..... going from vague memory here. I'd have to look at my transmissions or notes. One more thing.... the number 11 where yours has a 10 may be an indicator of LSD Or..... just rotate one of the drive flanges. IF the other one rotates in the same direction it's a LSD Opposite direction ? open rear. |
rgalla9146 |
Nov 29 2015, 01:56 PM
Hello Dennis
Don't have a 6 trans with LSD to check how it is designated Photos are of a rear shifter 4 cyl. with LSD The tag, the HB in the ID numbers and the hub turning test will tell the story. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 17th May 2024 - 05:52 PM |
