Porsche, AAR |
Porsche, AAR |
toon1 |
Nov 30 2015, 04:48 PM
Senior Member Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
I only described to the OP what happened to me TWICE.
I guess since I have a megasquirt system it's TOTALLY different....LOL |
era vulgaris |
Nov 30 2015, 05:08 PM
J is for Genius Group: Members Posts: 982 Joined: 10-November 13 From: Raleigh, NC Member No.: 16,629 Region Association: South East States |
I guess since I have a megasquirt system it's TOTALLY different....LOL Yeah...you probably should've mentioned that (IMG:style_emoticons/default/poke.gif) |
Nov 30 2015, 06:09 PM
914 Idiot Group: Members Posts: 14,991 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
my AAR was bad. There was likely something else that was going on... In a properly set up injection system (L-jet or D-jet!) the AAR should not affect the mixture. At all. The air going through the AAR is metered air; L-jet takes the air from downstream of the air flow meter, while the D-jet MPS sees the higher pressure of air getting in. In your case, there may have been something else going on. --DD |
lcjo73914 |
Dec 2 2015, 09:50 PM
Member Group: Members Posts: 56 Joined: 9-October 15 From: stockton - Ca Member No.: 19,250 Region Association: Northern California |
If you by pass the AAR with a straight hose you will find the idle will race up to over 2K. Then you can pinch the hose down to reduced the air flow and you will notice the rpms dropping. I found the hose has to be pinched real tight to get it to idle near 1K. I did this just as a test to see how the principal of the AAR worked. If you plug the hose ends or cut off all the air flow the engine will have a tough time idling when cold. It wants more air when cold. It can be frustrating I know, I have been trying to get my L-Jet to idle properly when cold. Even with the properly working AAR mine wont idle for a few minuets on its own. The AAR can be slightly adjusted to allow a bit more air flow with the end point stop. I have mine set to allow the most air flow. I am currently testing for air leaks and having the TB rebuilt. The TB's can become warn and cause leaks. The most important part of the L-Jet is to get rid of any Vacuum leaks. There are many places that can cause leaks. Thank you Pete |
JoeDees |
Dec 3 2015, 10:06 AM
Senior Member Group: Members Posts: 515 Joined: 10-November 14 From: Northern Kentucky Member No.: 18,106 Region Association: None |
The Army has warped my brain and I keep thinking AAR means After Action Review...
Lo-Fi Version | Time is now: 8th June 2024 - 04:12 AM |
