Clamp for Oil a Pressure Sender, What used ? |
jim_hoyland |
Nov 29 2015, 03:36 PM
Get that VIN ? Group: Members Posts: 9,300 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Is there a special clamp made for the VDO oil pressure sender ? It's about 1.6" in diameter.
Montreal914 |
Nov 29 2015, 03:46 PM
Senior Member Group: Members Posts: 1,560 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
You can use something like this (different diameter though):
http://www.ebay.com/itm/COL2809Z1-Clamp-OD...0-/321476708508 |
jim_hoyland |
Nov 29 2015, 04:12 PM
You can use something like this (different diameter though): http://www.ebay.com/itm/COL2809Z1-Clamp-OD...0-/321476708508 That'll work; I've seen those at Home Depot.... (IMG:style_emoticons/default/smile.gif) |
michael7810 |
Nov 30 2015, 07:57 AM
Senior Member Group: Members Posts: 1,081 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region |
This is what I used from the hardware store. Fit is just right. I've since painted it black. I think it cost a couple bucks at Ace.
cary |
Nov 30 2015, 08:10 AM
Dont have a picture. But mine is on a stand off piece. Then clamped to the sender. The stand off bolts to the fan housing.
IIRC it needs to be metal on metal for the ground? |
jim_hoyland |
Nov 30 2015, 09:24 AM
This is what I used from the hardware store. Fit is just right. I've since painted it black. I think it cost a couple bucks at Ace. I like that clamp, what's it called ? Think I may have seen them somewhere.... (IMG:style_emoticons/default/huh.gif) |
michael7810 |
Nov 30 2015, 09:58 AM
I believe it's made for clamping overhead iron pipe. 1-1/2" I think. Got it at Ace hardware.
maf914 |
Nov 30 2015, 04:16 PM
Yep, its a pipe clamp for hanging pipe overhead, often with threaded rod .
jim_hoyland |
Dec 1 2015, 05:43 PM
I believe it's made for clamping overhead iron pipe. 1-1/2" I think. Got it at Ace hardware. Couln't find at Lowes or the local Ace store. Need more info, iwithe the parts precise name or part number, I should be able to find in on Internet. What dept was it in ? |
Dtjaden |
Dec 1 2015, 05:57 PM
Member Group: Members Posts: 232 Joined: 25-May 13 From: Morgan Hill, CA Member No.: 15,915 Region Association: Northern California |
Hi Jim,
Here is the part at Homedepot: http://www.homedepot.com/p/Halex-1-1-2-in-...67840/100146334 Happy holidays! Darryl I believe it's made for clamping overhead iron pipe. 1-1/2" I think. Got it at Ace hardware. Couln't find at Lowes or the local Ace store. Need more info, iwithe the parts precise name or part number, I should be able to find in on Internet. What dept was it in ? |
michael7810 |
Dec 1 2015, 06:14 PM
That's exactly what I have. Make sure the size is correct...I'm thinking 1-1/2 may be small. They come in many sizes. I used a self locking nut on mine
jim_hoyland |
Dec 1 2015, 07:11 PM
wndsnd |
Dec 1 2015, 08:18 PM
You wanted a horse, but got a goat. Nobody wants a goat.... Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States |
That is an electrical conduit clamp.
LowBridge |
Dec 2 2015, 05:40 AM
Member Group: Members Posts: 370 Joined: 10-August 15 From: Lunenburg, MA Member No.: 19,045 Region Association: North East States |
michael7810 |
Dec 2 2015, 06:34 AM
I used a grease gun hose from FLAPS. I wasn't crazy about "threading" it into the case (not exactly the same threads) but it's a tried and proven method by several world gurus.
cwpeden |
Dec 2 2015, 08:41 AM
Pick your size. Grainger has everything...
http://www.grainger.com/product/B-LINE-by-...uit-Clamp-4RHZ6 |
LowBridge |
Dec 2 2015, 06:35 PM
thanks for the line info... I'll look into it because that sender really does not fit well next to the distributor
jim_hoyland |
Dec 2 2015, 06:43 PM
Update: Went to Home Depot. The first guy I asked didn't know; second guy did know. They don't carry the Halex 46840, but have ACC Conduit Hangers in 3 or 4 sizes. They are under $1.00 so I bought three different ones. The bases of one was a little flatter and better suited to mounting.
I'll shoot a pic and post later. In any case they have them... |
michael7810 |
Dec 2 2015, 08:58 PM
That's why I shop at Ace Hardware. At least at my local Ace, employees actually know what they have and are available and happy to help. Plus I get 10% military discount and a free bag of popcorn...I'm happy. Good luck
jim_hoyland |
Dec 4 2015, 06:28 PM
Got it in today, those clamps are perfect.
Lo-Fi Version | Time is now: 17th May 2024 - 03:00 PM |
