Control Arm Bushing Replacement, Degree of difficulty |
jack20 |
Nov 30 2015, 05:13 PM
Member Group: Members Posts: 406 Joined: 7-November 14 From: Granite Bay, CA Member No.: 18,099 Region Association: Northern California |
I need to replace the front rubber bushings and am planning to use the Elephant Racing bushings and install tools. I have not been able to find a video or other info regarding removal of the control arms. I am not near my car so I can't crawl under right now.
Will I need to remove the hubs, brakes or anything else to remove the control arms? Thanks, Jack |
Catorse |
Dec 1 2015, 08:20 PM
Member Group: Members Posts: 194 Joined: 27-August 15 From: Los Angeles Member No.: 19,106 Region Association: Southwest Region |
Easy! 20 ton press takes the bushings with the wings off in a couple minutes. There's no good place to grab the other end bushings on the press, so I use an air cut off tool and make a vertical slice down the steel bushing cap, effectively splitting it in half. Pops right off. Of course this method is only if you are using Rebel bushings and you don't need the stock ones.
Lo-Fi Version | Time is now: 22nd May 2024 - 01:03 AM |
