Bosch Dist. for 914-6 |
xsurfer |
Dec 3 2015, 09:52 AM
Member Group: Members Posts: 279 Joined: 4-April 06 From: La Canada, CA Member No.: 5,818 |
Can I use a Bosch 0231-159-006 in a 914-6 stock engine? Does the curve need to be modified? Need to end Marelli madness!
Thanks |
Gustl |
Dec 3 2015, 12:35 PM
914 enthusiast & historian Group: Members Posts: 11,504 Joined: 16-June 04 From: TIROL / Austria Member No.: 2,212 Region Association: Austria |
sorry, I only have it in German ...
Zündverteiler = Distributor Drehzahl-Abschaltung = rev. limiter |
Luke M |
Dec 3 2015, 01:00 PM
Senior Member Group: Members Posts: 1,372 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
What engine are you running a factory 2.0 ?
I have a Marelli distributor that came out of my 6. I know parts are getting harder to find for them. If you want to stick with the Marelli let me know as it's for sale. Send me a pm if that interests you. Here's a chart if it helps you. Attached image(s) |
Peashooter |
Dec 3 2015, 01:01 PM
Member Group: Members Posts: 163 Joined: 17-December 11 From: SW Ohio Member No.: 13,903 Region Association: None |
If it fits you can use it, but I would have it re-curved to match the specs of the current engine.
porschetub |
Dec 3 2015, 01:05 PM
Advanced Member Group: Members Posts: 4,699 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Can I use a Bosch 0231-159-006 in a 914-6 stock engine? Does the curve need to be modified? Need to end Marelli madness! Thanks Whats the marelli madness,hope I haven't got that to look forward to (IMG:style_emoticons/default/confused24.gif) . I was lead to believe any of Bosch distributers use on the carbed T models will work,even the early cast iron one will work as long as it wasn't from the S motor. Do the Webers have provision to deliver vacuum to the distributor?. Hope you find the right one as they are getting expensive and hard to find,you would certainly need to make sure whatever you buy is in good working condition. |
mskala |
Dec 3 2015, 01:51 PM
Can I use a Bosch 0231-159-006 in a 914-6 stock engine? Does the curve need to be modified? Need to end Marelli madness! Thanks I don't have the curves handy, but you should be able to see from searching the Pelican 911 tech board. Curve is different, max advance is different (30 vs. 35), heads are way different, cams are way different. I'm not sure what your goal is. Buying or modifying a Bosch dist will be at least $500. You could find a bunch of working marelli parts cheaper than that and if you're not driving 10000 mi/year you should not have to work hard or spend much to keep it going. |
porschetub |
Dec 3 2015, 04:01 PM
Can I use a Bosch 0231-159-006 in a 914-6 stock engine? Does the curve need to be modified? Need to end Marelli madness! Thanks I don't have the curves handy, but you should be able to see from searching the Pelican 911 tech board. Curve is different, max advance is different (30 vs. 35), heads are way different, cams are way different. I'm not sure what your goal is. Buying or modifying a Bosch dist will be at least $500. You could find a bunch of working marelli parts cheaper than that and if you're not driving 10000 mi/year you should not have to work hard or spend much to keep it going. Good points and (IMG:style_emoticons/default/agree.gif) ,you can get caps for them now,points are cake and pertronix make a unit,people also overhaul them. Theres not a lot to go wrong with these distributors as there is pretty much nothing to them,I note there are still a lot of 911 guys still using them. The chart provided indicates there isn't much choice infact it basically shows the 911T 2.0 as being the only choice without recurving,this are hard to find @ a reasonable price besides. Theres a guy on the bird username fishcop,he had a company in Australia modify an early BMW six one to good result but the cost was up there. |
Mark Henry |
Dec 3 2015, 04:17 PM
Or you could go crankfire using a Megajolt jr, MegaSquirt running ignition only or the CE unit.
Then you can change the curve to whatever you like. |
Mark Henry |
Dec 3 2015, 04:21 PM
I don't know if this is a good source or price but :
https://www.autosportlabs.com/product/megajolte/ https://www.youtube.com/watch?v=4PaL3yDuX8Y |
Lo-Fi Version | Time is now: 17th May 2024 - 03:45 PM |
