WTB 1972 3 port fuel pump, WTB |
tmaney |
Dec 7 2015, 12:59 PM
Newbie Group: Members Posts: 15 Joined: 22-July 03 From: Northern Virginia Member No.: 932 Region Association: MidAtlantic Region |
Looking for some help in getting my car back on the road, have determined that my fuel pump has failed and wanted to keep it stock. I have a 1972 914 with factory d-jet fuel injection. Would prefer a rebuilt unit or some ones tested spare. Thanks.
Dec 7 2015, 01:50 PM
Make sure you put some power to your pump to check it. I thought mine had failed but it ran when we put power to it. Replaced the relay board and car ran again.
tmaney |
Dec 7 2015, 01:56 PM
Thanks I checked all relays and fuses and replaced the board with a new one, which was in much better shape than the one I had in the car. I have recently replaced the gas tank and am guessing some debris has caused the pump to fail...
McMark |
Dec 8 2015, 07:09 AM
Look closely at the pump electrical connector and you'll see a + and - embossed into the body near the plug. Use some generic wire and spade connectors to make jumper wires. Touch them to the battery and see if it pumps. You CAN and SHOULD connect them backwards as well. This just spins the pump backwards and can help dislodge things. Make sure you have a good fuel filter inline after the pump.
If you still need to replace your pump, contact Fuel Injection Corp. They rebuild the stock pumps. |
tmaney |
Dec 8 2015, 01:48 PM
Look closely at the pump electrical connector and you'll see a + and - embossed into the body near the plug. Use some generic wire and spade connectors to make jumper wires. Touch them to the battery and see if it pumps. You CAN and SHOULD connect them backwards as well. This just spins the pump backwards and can help dislodge things. Make sure you have a good fuel filter inline after the pump. If you still need to replace your pump, contact Fuel Injection Corp. They rebuild the stock pumps. Thank you very much for your comments, will check it again and let you know. Best, Tim |
tmaney |
Dec 14 2015, 12:36 PM
Checked wiring again this weekend, applied 12v to both connections and the pump is still seized. I need a new pump or to have this one rebuilt.
Dec 14 2015, 12:41 PM
I have a spare. Pm me your address and I'll send you a pump
Lo-Fi Version | Time is now: 17th May 2024 - 04:42 PM |
