QUOTE(McMark @ Dec 8 2015, 05:09 AM)
Look closely at the pump electrical connector and you'll see a + and - embossed into the body near the plug. Use some generic wire and spade connectors to make jumper wires. Touch them to the battery and see if it pumps. You
CAN and
SHOULD connect them backwards as well. This just spins the pump backwards and can help dislodge things. Make sure you have a good fuel filter inline after the pump.
If you still need to replace your pump, contact
Fuel Injection Corp. They rebuild the stock pumps.
Thank you very much for your comments, will check it again and let you know. Best, Tim
