914 2.8 Type IV Auto-X Killer SOLD SOLD SOLD |
Bobby Smith |
Dec 9 2015, 11:02 AM
Newbie Group: Members Posts: 27 Joined: 19-July 07 From: VA Beach VA Member No.: 7,926 |
This 914 was for sale a few years ago and the post got over 16,000 views and went to 4 pages. It's a bit overwhelming so I thought I'd start over. I'm having a weak moment and want to "test the waters" for a potential buyer. Looking at $15K.
The original post and comments are here: http://www.914world.com/bbs2/index.php?showtopic=114227 73 914/4 2.8 liter. FTD Winner 2008 Porsche Parade Charlotte NC Engine built by FAT Performance with the absolute best components that money can buy. Cost $10,445 Broken in on Dyno Dyno sheet: 194 HP at 6,000 RPM and 215 ft lbs Torque from 3,500-5,000. (*note: has 200 ft lbs at 3,000*) Specs: 2755cc Okrasa billet crank Carillo Rods J&E pistons and cyls. 44 IDF dual webers 10:1 C/R Header system with Supertrapp and open setup No oil leaks MSD ignition system with soft touch rev limit/Autometer tach Lightweight flywheel with Hi performance Kenedy clutch pack Twin oil coolers and thermostat Deep sump oil trap High Torque starter Heads are fresh Trans: Original 914 transmission with Renegade 914 axle/CV joint upgrade (good for 500 HP) Custom Transmission with airport gears available as option (will discuss price) Suspension: Adj Sport Koni's all 4 corners Rear Adj spring coil overs with 175 lbs Hypercoils/Recently have been using JRZ rear shocks and Eibach springs Front 22mm torsion bars Addco anti-sway bars with delrin bushings Turbo Tie rod ends Rack spacers Performance 4 wheel alignment Fiber glass Hood, trunk, bumpers, flairs Weighs 1650 lbs wet Spun Aluminum fuel tank New 19mm Master Cyl. BMW front calipers Front 914 calipers mounted on rear stock rotors Proportioning valve Lightweight Centerline Racing wheels 10x15 with Hoosier slicks Auto Power bolt in roll hoop with cross brace Simpson 5 point belt system Custom made tonnau cover for transporting in inclement weather Battery disconnect switch Battery located in passenger floor 19mm Master Cyl New Avon slicks with only a hand full of runs on them. I have owned this 914 since 1982. I am sure there is more that I have forgotten. She's well sorted and ready to take you to your first FTD. Please feel free to contact me with any questions and I would be happy to provide technical assistance after the sale if needed. This is my Baby and she has brought much joy over the years. Bobby Smith 757 463-7294 First Settlers Region/Porsche Club of America VA Beach VA |
Lo-Fi Version | Time is now: 17th May 2024 - 10:24 PM |
