This 914 was for sale a few years ago and the post got over 16,000 views and went to 4 pages. It's a bit overwhelming so I thought I'd start over. I'm having a weak moment and want to "test the waters" for a potential buyer. Looking at $15K.
The original post and comments are here:
http://www.914world.com/bbs2/index.php?showtopic=114227
73 914/4 2.8 liter.
FTD Winner 2008 Porsche Parade Charlotte NC
Engine built by FAT Performance with the absolute best components that money can buy.
Cost $10,445
Broken in on Dyno
Dyno sheet: 194 HP at 6,000 RPM and 215 ft lbs Torque from 3,500-5,000. (*note: has 200 ft lbs at 3,000*)
Specs:
2755cc
Okrasa billet crank
Carillo Rods
J&E pistons and cyls.
44 IDF dual webers
10:1 C/R
Header system with Supertrapp and open setup
No oil leaks
MSD ignition system with soft touch rev limit/Autometer tach
Lightweight flywheel with Hi performance Kenedy clutch pack
Twin oil coolers and thermostat
Deep sump oil trap
High Torque starter
Heads are fresh
Trans: Original 914 transmission with Renegade 914 axle/CV joint upgrade (good for 500 HP)
Custom Transmission with airport gears available as option (will discuss price)
Suspension:
Adj Sport Koni's all 4 corners
Rear Adj spring coil overs with 175 lbs Hypercoils/Recently have been using JRZ rear shocks and Eibach springs
Front 22mm torsion bars
Addco anti-sway bars with delrin bushings
Turbo Tie rod ends
Rack spacers
Performance 4 wheel alignment
Fiber glass Hood, trunk, bumpers, flairs
Weighs 1650 lbs wet
Spun Aluminum fuel tank
New 19mm Master Cyl.
BMW front calipers
Front 914 calipers mounted on rear
stock rotors
Proportioning valve
Lightweight Centerline Racing wheels 10x15 with Hoosier slicks
Auto Power bolt in roll hoop with cross brace
Simpson 5 point belt system
Custom made tonnau cover for transporting in inclement weather
Battery disconnect switch
Battery located in passenger floor
19mm Master Cyl
New Avon slicks with only a hand full of runs on them.
I have owned this 914 since 1982. I am sure there is more that I have forgotten. She's well sorted and ready to take you to your first FTD.
Please feel free to contact me with any questions and I would be happy to provide technical assistance after the sale if needed. This is my Baby and she has brought much joy over the years.
Bobby Smith
757 463-7294
First Settlers Region/Porsche Club of America
VA Beach VA
