From the reservoir to the Master Cylinder, ::: What Hose To Use? ::: |
Rusty |
Mar 14 2005, 08:36 AM
Did you get a picture? (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) Where did you source your blue braided hoses? -Rusty (IMG:http://www.914world.com/bbs2/html/emoticons/smoke.gif) |
McMark |
Mar 14 2005, 09:59 AM
Doug, as I said earlier, I HAVE A SET OF #11/12, WHERE SHOULD I SHIP THEM? Sheesh. Sometimes I think I'm talking to myself. (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif) |
davep |
Mar 14 2005, 10:25 AM
914 Historian Group: Benefactors Posts: 5,138 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
I've never used a 17mm as a replacement in 29 years. That must mean I have used a lot of 19mm. Gotta get to work on those 20mm some day. |
CptTripps |
Mar 14 2005, 10:26 AM
:: Punch and Pie :: Group: Members Posts: 3,584 Joined: 26-December 04 From: Mentor, OH Member No.: 3,342 Region Association: Upper MidWest |
Thanks McMark. I was gettiing there...
PM Sent. |
McMark |
Mar 14 2005, 10:40 AM
Series9 |
Mar 14 2005, 12:45 PM
Keep in mind:
Larger master cylinder=Less leverage This is a mistake many people make. A 19mm MC is NOT an upgrade as many places advertise. What you get is a firmer pedal because you have less leverage to apply your brakes. You don't need a larger MC unless you have much more than factory brakes. I have a 19mm w/a total of 20 pistons at the wheels. Your stock brakes have a total of 8. That being said, I probably need a slightly larger MC and may replace it this year, but like I said, I NEED something larger to move the amount of fluid required to operate 20 pistons. |
CptTripps |
Mar 14 2005, 12:58 PM
Just called PP and bought a new 19mm, all new lines, new pads, rebuild parts, and a speed-bleeder.
I'm going to add a T to the back in place of the prop valve and re-build all 4 calipers. If I aint stoppin' after all that, I need to find another hobby! I also ordered a few feet of the blue hose to replace what I cut off. I still need the feeder lines though. Jsut to make sure! |
Lo-Fi Version | Time is now: 6th May 2024 - 12:45 PM |
