Hard Starting Problem, Any ideas? |
jack20 |
Dec 19 2015, 10:53 AM
Member Group: Members Posts: 406 Joined: 7-November 14 From: Granite Bay, CA Member No.: 18,099 Region Association: Northern California |
Ever since I fixed all of the vacuum leaks I've had a difficult time starting the car. It's a 74 2.0 with stock injection. My routine is to cycle the key 4 times then crank. After about the 4th time it will want to run but only if I pump to keep it running. Then it smooths right out and runs great.
Prior to fixing the vacuum leaks it started right up but idled at around 2k. Any thoughts? Thanks, Jack |
boxsterfan |
Dec 19 2015, 12:25 PM
914's are kewl Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
Possibilities:
1. Clogged/partially clogged fuel sock in the gas tank 2. Partially Crimped/bent fuel hose up by the tank or in the engine bay 3. Butterly valve on the intake not opening/closing properly 4. Throttle cable is binding up You could also verify that you are getting spark at the plug wires when cranking. |
Highland |
Dec 19 2015, 12:34 PM
Senior Member Group: Members Posts: 513 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California |
You may already have done this, but I would verify AAR valve is open at startup.
I'm struggling with a similar problem. I wouldn't pump the pedal, but would have to crack it until warm up. My initial idle is still low, but what really helped was setting valve lash to .002~.003". I was at 0 lash with steel pushrods and RAT 9590 cam. My guess is a wasn't getting compression at initial startup because of the immediate expansion of the exhaust valve. Wondering if you have a similar issue if the car runs smooth after warm up. |
jack20 |
Dec 19 2015, 07:31 PM
Thanks very much guys. Probably should have mentioned that this is a cold starting issue after a complete cool down, like overnight. Starts eagerly when warm and exhibits no fuel starvation symptoms when driving. A cold temp in this area would be 50F So,from what I've read, the cold start valve doesn't come into play. When cold, I cycle the key 4-5 times, while listening for the fuel pump. I then hit start and it sounds like it wants to run but then dies. On each try, it runs a little longer but still dies. On about the 5 try it is really trying to stay running and if I pump the pedal it will stumble, maybe pop in the TB and then begin running smoothly. If I hadn't read differently I would immediately suspect the cold start valve. btw, I tried testing the csv by placing it in a glass jar while cranking. No fuel. That was before I read that the valve is pretty much useless where I live. I will pull the AAR and go through the process I read on a recent thread. |
Lo-Fi Version | Time is now: 17th May 2024 - 07:53 PM |
