Front sway bar drop link lenght |
GaroldShaffer |
Dec 19 2015, 01:42 PM
Can anyone do a quick measurement on stock front sway bar drop link. I just need the total end to end measurement of the drop link. Trying to determine which of on these two is the correct length. The measurements are 220mm and 265 mm. That measurement is from outside to outside total over all length.
Thanks. Attached image(s) |
bdstone914 |
Dec 19 2015, 01:46 PM
bdstone914 Group: Members Posts: 4,523 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I can get you measurements when i am back at the shop. Looks like you have one 914 and one SWB 911 link which would be about 1-1/2 longer.
toadman |
Dec 19 2015, 02:19 PM
Member Group: Members Posts: 168 Joined: 26-December 05 From: Cincinnati, OH Member No.: 5,316 |
I measured two spare front sway bar drop links that I have. One is 253 mm and one is 262 mm, more or less, total overall length. Based on these measurements, I think the longer one that you have is the stock length.
914Sixer |
Dec 19 2015, 05:46 PM
914 Guru Group: Members Posts: 8,886 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
I measured 220 mm end to end.
MartyYeoman |
Dec 19 2015, 06:00 PM
Senior Member Group: Members Posts: 1,519 Joined: 19-June 03 From: San Ramon, CA Member No.: 839 Region Association: Northern California |
22cm
Attached thumbnail(s) |
bobheinonen |
Dec 19 2015, 07:55 PM
Newbie Group: Members Posts: 10 Joined: 16-September 08 From: San Diego, CA Member No.: 9,556 Region Association: Southern California |
The length is correct when the arm on the end of the swaybar is parallel to the ground. Told to me by a veteran autocrosser many years ago when I was setting up my 914-6. Adjustable drop links are often a good idea. Bob
bdstone914 |
Dec 19 2015, 08:31 PM
I was off on my original estimate of lenghts. Here is,a 014 and LWB 911. I think you have one 914 and SWB 911 drop link. (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beerchug.gif)
johnhora |
Dec 20 2015, 12:55 PM
Senior Member Group: Members Posts: 866 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None |
bdstone914 |
Dec 20 2015, 02:51 PM
No, 911 is longer. The Weltmeister are the same length as OE but are a straight tube on the part where the bushing goes. The OE are crown shaped inside. |
Lo-Fi Version | Time is now: 21st May 2024 - 06:54 AM |
