need midwest machine shop, took apart the 911 |
Dec 25 2015, 03:41 PM
914-6 GT in waiting Group: Members Posts: 19,316 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Rod bolts can't be reused but it's up to you to decide on stock or aftermarket.
Luke M |
Dec 26 2015, 09:27 AM
Senior Member Group: Members Posts: 1,377 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
On my brothers 3.0 rebuild we used the factory rod bolts.
If your budget allows then get the ARP or other brand rod bolts. I do believe there's a streach gauge you need as well. I didn't see a need for more then the factory bolts on a street car. Do your homework before you buy your bearings. There's been issues with the rod bearings. As for the head studs I used all steel Porsche studs on his 3.0. |
worn |
Dec 26 2015, 12:36 PM
can't remember Group: Members Posts: 3,164 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
On my brothers 3.0 rebuild we used the factory rod bolts. If your budget allows then get the ARP or other brand rod bolts. I do believe there's a streach gauge you need as well. I didn't see a need for more then the factory bolts on a street car. Do your homework before you buy your bearings. There's been issues with the rod bearings. As for the head studs I used all steel Porsche studs on his 3.0. Thanks. Sounds like what I was planning. Gawd. Having to do homework to find quality bearing shells? OK. Any pointers? If I buy from the bird will I be safe? With bearings rings gasket sets etc - no big parts - my wish list is floating at 2 grand (IMG:style_emoticons/default/wacko.gif) |
Lo-Fi Version | Time is now: 11th June 2024 - 06:39 AM |
