All Reverse All the Time, Replaced bushings results in only reverse gear |
Twonicks001 |
Dec 23 2015, 04:21 PM
Newbie Group: Members Posts: 32 Joined: 14-December 15 From: Texas Member No.: 19,458 Region Association: Southwest Region |
1972 - 4cyl - Original Tail shifter - Just changed all the shifter bushings and am in process of getting alignment right on shifter rods. Thought I had several, if not all gears so put car back on ground to test. What felt like reverse was reverse ... but what felt like second was also reverse...and... what felt like third was also reverse...anybody have an idea of what I did to cause this. Nothing appears unattached fom the selector through the firewall. Could I have somehow gotten the shifter fork at the transmission hung up in reverse? Anyone that has a thought, please pass it on before I start opening everything up again.
xperu |
Jan 4 2016, 10:04 AM
TEXAS Group: Members Posts: 597 Joined: 13-June 06 From: League City Texas Member No.: 6,213 Region Association: None |
1972 - 4cyl - Original Tail shifter - Just changed all the shifter bushings and am in process of getting alignment right on shifter rods. Thought I had several, if not all gears so put car back on ground to test. What felt like reverse was reverse ... but what felt like second was also reverse...and... what felt like third was also reverse...anybody have an idea of what I did to cause this. Nothing appears unattached fom the selector through the firewall. Could I have somehow gotten the shifter fork at the transmission hung up in reverse? Anyone that has a thought, please pass it on before I start opening everything up again. Hi, I'm not a transmission guy by any means, but I see you haven't had any responses to your post. I lost all my shifting capabilities all of a sudden. the problem was my bushing at the firewall had completely failed. I believe it was the original bushings. Replaced all and everything was fine. also it may be the cone screw that has backed out our missing, this is not uncommon to be the case with this bushing and will cause shift mayhem. I would also post your problem on the garage forum for more exposure to you question. Mike P.S. I also live south of Houston off I-45 in League City |
Lo-Fi Version | Time is now: 20th May 2024 - 04:26 AM |
