All Reverse All the Time, Replaced bushings results in only reverse gear |
Twonicks001 |
Dec 23 2015, 04:21 PM
Newbie Group: Members Posts: 32 Joined: 14-December 15 From: Texas Member No.: 19,458 Region Association: Southwest Region |
1972 - 4cyl - Original Tail shifter - Just changed all the shifter bushings and am in process of getting alignment right on shifter rods. Thought I had several, if not all gears so put car back on ground to test. What felt like reverse was reverse ... but what felt like second was also reverse...and... what felt like third was also reverse...anybody have an idea of what I did to cause this. Nothing appears unattached fom the selector through the firewall. Could I have somehow gotten the shifter fork at the transmission hung up in reverse? Anyone that has a thought, please pass it on before I start opening everything up again.
Twonicks001 |
Jan 4 2016, 01:43 PM
Mike,
Thanks for the response...problem was I am a newbie here and posted initially on the wrong forum. There is no way to remove it after its posted so....I did post on the garage forum and got several suggestion...all of which helped in one way or another. My problem, started like yours, with a completely worn out and partially missing firewall bushing...thanks again Dennis |
Lo-Fi Version | Time is now: 20th May 2024 - 04:29 AM |
