Your thoughts on fire extinguishers, Pelican parts sale |
campbellcj |
Apr 6 2019, 03:16 PM
I can't Re Member Group: Members Posts: 4,568 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
TLG Auto in N. Hollywood (Marco) now carries and endorses the Element. I've not seen and definitely not tested one myself, yet.
Superhawk996 |
Apr 6 2019, 05:29 PM
914 Guru Group: Members Posts: 6,469 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
I'll be the voice of dissent.
Not a fan of fire bottles in the passenger compartment. Usually a mounted by flimsy brackets that fail to hold the bottle in a crash. Now you have a loose 5-10 pound projectile in the passenger compartment. I've had the opportunity to see both sides of this in play. As previously stated by others a small hand held is of limited use on a fuel fire. In my case, it wasn't enough to put out the fire. (IMG:style_emoticons/default/sad.gif) I've also seen vehicles in track day related crashes where the fire bottle came loose. Luckily driver had a helmet on. (IMG:style_emoticons/default/biggrin.gif) Put in Trunk or Frunk. Maybe one in each but I'd keep it out of the passenger compartment. |
oakdalecurtis |
Apr 6 2019, 06:55 PM
Oakdalecurtis Group: Members Posts: 1,336 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California |
Here's my fire solution(s). I have a BlazeCut system installed under the lid. I do not use a rain tray since I NEVER drive in the wet. I painted the BlazeCut tube black so that it does not show through the engine cover. You might also notice the engine deck lid steel cable restraint on the left side so that when I pop the lid, the hinges aren't slammed and worked until breakage ensues.
And just in case I have a cabin fire, I have a Kidde extinguisher inside my custom built center console box..... (IMG:style_emoticons/default/piratenanner.gif) |
Coondog |
Apr 6 2019, 07:58 PM
Advanced Member Group: Members Posts: 2,089 Joined: 24-September 15 From: Apple Valley Calif Member No.: 19,195 Region Association: Southern California |
porschetub |
Apr 7 2019, 03:06 PM
Advanced Member Group: Members Posts: 4,723 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I'll be the voice of dissent. Not a fan of fire bottles in the passenger compartment. Usually a mounted by flimsy brackets that fail to hold the bottle in a crash. Now you have a loose 5-10 pound projectile in the passenger compartment. I've also seen vehicles in track day related crashes where the fire bottle came loose. Luckily driver had a helmet on. (IMG:style_emoticons/default/biggrin.gif) Put in Trunk or Frunk. Maybe one in each but I'd keep it out of the passenger compartment. In my country you can't pass tech inspection if your extinguisher isn't motorsport rated,the same size/type household ones only have flimsy metal mounting brackets,my 2 motorsport rated one's have a much heaver construction and very sturdy over-centre clips,there is a difference in price but well worth it to know they can't come loose. |
Dion |
Apr 7 2019, 03:17 PM
RN Group: Members Posts: 2,792 Joined: 16-September 04 From: Audubon,PA Member No.: 2,766 Region Association: MidAtlantic Region |
When I’m done with my 6 build (is that even possible?) I plan on using this....
Attached thumbnail(s) |
burton73 |
Apr 7 2019, 05:13 PM
burton73 Group: Members Posts: 3,650 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
Here's my fire solution(s). I have a BlazeCut system installed under the lid. I do not use a rain tray since I NEVER drive in the wet. I painted the BlazeCut tube black so that it does not show through the engine cover. You might also notice the engine deck lid steel cable restraint on the left side so that when I pop the lid, the hinges aren't slammed and worked until breakage ensues. And just in case I have a cabin fire, I have a Kidde extinguisher inside my custom built center console box..... (IMG:style_emoticons/default/piratenanner.gif) I think this may be the ticket but in the cabin Element Fire Extinguisher Group Buy and Rennline's Newest Fire Extinguisher Mount! This may be the set up I will be using for my 6 Bob B |
Lo-Fi Version | Time is now: 20th September 2024 - 04:41 PM |
