help, rear trunk |
help, rear trunk |
steven1826 |
Mar 15 2005, 07:36 AM
Newbie Group: Members Posts: 5 Joined: 9-February 05 From: kokomo In. Member No.: 3,584 |
I have a 70 914/6 that I can't get the rear trunk open, looks like the rear lock may have been jimmied.
Any suggestions? (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif) |
rhodyguy |
Mar 15 2005, 07:42 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,081 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
the release button does nothing at all? is it unlocked? try gently pushing down on the rear edge of the trunk while pushing the button, then try to lift it while the button is still in.
k |
Mar 15 2005, 12:25 PM
yes, 2 solutions. i have tried both and i find number 2 much easier! 1. open the engine lid, remove the lid for easier access (2 10mm nuts). then, unbolt the trunk lid bolts from the pivot hinges. be careful if you still have the torsion bars in there. that will allow you to lift the rear of the lid enough to get a long ratched extension (just put a few pieces together) in there. have someone else help you with a flashlight. the lock for the rear trunk is bolted down with 2 10 mm nuts. it's a lot of trial & error, but it can be done that way. 2. open the engine lid. (remove for easier access, if needed, see 1.) then, pop out the 2 round plastic cups in the rear firewall that hold the targa top latches. have someone else help you with a flashlight through the pass. side opening. use a unfolded coat-hanger through the drivers side opening. make sure the hanger is straight except a small "hook" on the end. on the bottom of the rear lock, there's a little "nipple" that's exposed that the rear lock cylinder is pushing towards the front of the car to open the lid. get the coat hanger behind that "nipple" and pull. voila! done it both ways and i find 2. much easier IHMO ... (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) Andy |
Lo-Fi Version | Time is now: 21st May 2024 - 12:36 PM |
