fuel injection restoration |
michaelmoo |
Mar 15 2005, 12:03 PM
Member Group: Members Posts: 312 Joined: 21-May 04 From: Kennesaw, GA Member No.: 2,092 |
Anyone do a physical restoration of there fuel injection? I know I have seen guys that paint their intake runners red or yellow or what ever color they want. What paint? What method was used to clean them? Bead blasting, sand blasting? Mine has a little surface rust around the injector holes (been sitting in a box for almost 25 years) and I would like to “refresh” them. Tips?
72914S |
Mar 15 2005, 12:21 PM
love this shot Group: Members Posts: 1,290 Joined: 10-July 03 From: Pensacola,Fl. Member No.: 900 Region Association: South East States |
I had mine sand blasted and powder coated. Barry
dmenche914 |
Mar 15 2005, 12:29 PM
Senior Member Group: Members Posts: 1,212 Joined: 27-February 03 From: California Member No.: 366 |
Sanding or paint strippers work well to remove the old paint, Be very careful that all rust is removed from inside the runners, as it might later break loose, and get inside your engine. Same goes for sanding grit, so make sure the insides are spotless clean, and rust free.
For the paint, i use a gloss engine enamal from a spray can (takes heat well) I have started to leave the aluminum casting on the head side of the runners as bare aluminum, rather than paint, as they have gotten hot enough to darken the paint over time, but the steel tubes remain cool enough. I like orange, it adds 5 to 7% more horse power! |
JeffBowlsby |
Mar 15 2005, 02:26 PM
914 Wiring Harnesses Group: Members Posts: 8,510 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
You looking for a stock look or are you going to do something unique??
michaelmoo |
Mar 15 2005, 03:17 PM
I really want a stock look.
gregrobbins |
Mar 15 2005, 04:35 PM
Member: Team NARP Group: Members Posts: 1,515 Joined: 23-March 04 From: Arizona Member No.: 1,844 Region Association: Southwest Region |
Thats news to me, all this time they said yellow is faster. Go figure. (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) |
Lo-Fi Version | Time is now: 21st May 2024 - 11:41 AM |
