oil pressure problem, too much when cold |
bernbomb914 |
Mar 15 2005, 12:58 PM
one of the oldest Farts on this board Group: Benefactors Posts: 1,873 Joined: 29-December 02 From: Temecula, CA Member No.: 36 |
I have a problem. When the engine is cold I have too much pressure and have blowen the oil filter twice. big mess. I am running 30 wt oil while I am breaking the engine in. we made a adjustable spring tension plug to keep the the pressure up when it is hot but it makes it to high when it is cold. I need a bypass from the filter when the oil is cold. I have a a external oil cooler with a thermostat built into the filter cartrage housing. Is there a differant way that wont cause this problem? I am going to Royal purple 20-40 syn. this time with a wix oil filter. Any Suggestions
Bernie |
Lo-Fi Version | Time is now: 29th May 2024 - 02:45 PM |
