Engine and Trans - Oil Recommendation |
FastFroggy |
Dec 28 2015, 07:48 AM
Newbie Group: Members Posts: 43 Joined: 27-November 15 From: Ann Arbor MI Member No.: 19,415 Region Association: Upper MidWest |
I am getting ready to do my first engine and trans oil change on my 914 track car. I run an accusump if it matters
Looks like previous owner was putting redline 15-50 in the engine. Book calls for straight 30w. I generally prefer Mobil One and was planning 15-50. Any thoughts? Then for the transmission, book call for 90w. I was again planning for Mobil One manual trans oil. if I can find it. Any thoughts? Thanks |
brant |
Dec 28 2015, 09:25 AM
914 Wizard Group: Members Posts: 11,620 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
You need oil with zddp
It's debated whether mobile one has it or not |
Randal |
Dec 28 2015, 12:17 PM
I've always used Kendell GT-1 in my racing engines as the zinc content is high. Never a bad experience. Swepco is my go to fluid for transmissions. BUT not even Swepco will keep you from buzzing the syncros in first to second or second to third shifts.
FastFroggy |
Dec 28 2015, 04:58 PM
I was just looking at the following reference info.
https://mobiloil.com/~/media/amer/us/pvl/fi...specs-guide.pdf Looks like 15W-50 is rated for flat tappet applications. Thanks for the assist. |
Cracker |
Dec 28 2015, 09:10 PM
Advanced Member Group: Members Posts: 2,148 Joined: 2-February 10 From: Atlanta (area) Member No.: 11,316 Region Association: South East States |
FWIW: I run Mobile One 15-50 in my LS 914 and my D-Sportsracer. It is cheap enough that I only run two-weekends with it and start afresh.
Tony |
Randal |
Dec 29 2015, 10:19 AM
FWIW: I run Mobile One 15-50 in my LS 914 and my D-Sportsracer. It is cheap enough that I only run two-weekends with it and start afresh. Tony Trusting you had a Merry Christmas and best wishes for the 2016 New Year! You need to post some pictures of your D Sport on here as well. Video also welcome. |
FastFroggy |
Dec 29 2015, 10:23 AM
Still on subject: has anyone tried 0w50 Mobil One Race Oil in a 4cylinder? Seems too thin. Just figured to ask. ZDDP is really high.
Thanks |
kupcar |
Dec 29 2015, 01:57 PM
Member Group: Members Posts: 95 Joined: 14-February 13 From: Chicago Member No.: 15,528 Region Association: None |
Froggy, if you like Mobile 1, then my recommendation would be Mobile V-Twin. The zinc levels are very good. I have also used Valvoline VR-1. Also good zinc numbers and a bit easier on the pocketbook than the Mobile. For the gearbox, Swepco 201. Hope that helps.
Randal |
Dec 29 2015, 02:50 PM
Froggy, if you like Mobile 1, then my recommendation would be Mobile V-Twin. The zinc levels are very good. I have also used Valvoline VR-1. Also good zinc numbers and a bit easier on the pocketbook than the Mobile. For the gearbox, Swepco 201. Hope that helps. That's the oil that Mat Lowrance recommends, i.e., Mobile V-Twin. He's a big time engine builder in Reno. |
jmill |
Dec 30 2015, 01:52 PM
You need oil with zddp (IMG:style_emoticons/default/agree.gif) Unfortunately, I grenaded an engine with a high lift flat tappet cam before I knew the additive was removed. |
jmill |
Dec 30 2015, 02:07 PM
Mobil 1 has it but at about half the levels of V twin or their racing oils.
Attached thumbnail(s) |
FastFroggy |
Dec 31 2015, 07:15 AM
Well understand ZDDP is needed. Question is how much. 15W-50 is listed at 1200phos and 1300zinc... I am nervous about it but the Mobil 1 guide does say "HT/HS applications, Racing and Flat tappet applications.". Question is how much is necessary? I filled with 15w-50 for now. Doing my first once thru on all systems. Will look to change probably after one or two events anyway.
Cracker |
Dec 31 2015, 08:02 AM
Kermit: Is this a 2, 4, 6, or 8 cylinder?
Randal: Here you go...this car has a full CF body (2 clips) and Stohr wing. Lots of fun...NOW, back to the oily discussion. This is more fun though... (IMG:style_emoticons/default/poke.gif) Tony FWIW: I run Mobile One 15-50 in my LS 914 and my D-Sportsracer. It is cheap enough that I only run two-weekends with it and start afresh. Tony Trusting you had a Merry Christmas and best wishes for the 2016 New Year! You need to post some pictures of your D Sport on here as well. Video also welcome. |
Randal |
Dec 31 2015, 12:40 PM
Nice chassis (IMG:style_emoticons/default/icon8.gif) but keeping on topic, which oil you running in that GSXR? (IMG:style_emoticons/default/biggrin.gif)
Oh, you have tunnels on the DSR, very impressive! |
campbellcj |
Dec 31 2015, 09:13 PM
I can't Re Member Group: Members Posts: 4,543 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
My builder also uses the V-Twin. I've used that, and Brad Penn.
eimc |
Jan 1 2016, 09:37 AM
Newbie Group: Members Posts: 45 Joined: 2-October 04 From: Mechanicsburg Penna. Member No.: 2,873 Region Association: None |
I am getting ready to do my first engine and trans oil change on my 914 track car. I run an accusump if it matters Looks like previous owner was putting redline 15-50 in the engine. Book calls for straight 30w. I generally prefer Mobil One and was planning 15-50. Any thoughts? Then for the transmission, book call for 90w. I was again planning for Mobil One manual trans oil. if I can find it. Any thoughts? Thanks Use Sweepco in trans and never have to worry |
brant |
Jan 1 2016, 10:40 AM
Change motor oil after every race.
I'm currently using redline (lt wt shockproof) in the trans and having great results |
PotterPorsche |
Mar 7 2016, 10:14 PM
Member Group: Members Posts: 295 Joined: 10-November 13 From: Hayward CA Member No.: 16,628 Region Association: None |
Brad penn 10/30 20/50 up to you, high ziinc content.
http://www.ebay.com/itm/Brad-Penn-Grade-1-...%3D200591297651 $6.50 a quart shipped. |
FastFroggy |
Mar 13 2016, 05:25 PM
thanks.... great price too!
Lo-Fi Version | Time is now: 6th May 2024 - 12:26 PM |
