FastFroggy
Dec 28 2015, 07:48 AM
I am getting ready to do my first engine and trans oil change on my 914 track car. I run an accusump if it matters
Looks like previous owner was putting redline 15-50 in the engine. Book calls for straight 30w. I generally prefer Mobil One and was planning 15-50. Any thoughts?
Then for the transmission, book call for 90w. I was again planning for Mobil One manual trans oil. if I can find it. Any thoughts?
Thanks
brant
Dec 28 2015, 09:25 AM
You need oil with zddp
It's debated whether mobile one has it or not
Randal
Dec 28 2015, 12:17 PM
I've always used Kendell GT-1 in my racing engines as the zinc content is high. Never a bad experience. Swepco is my go to fluid for transmissions. BUT not even Swepco will keep you from buzzing the syncros in first to second or second to third shifts.
FastFroggy
Dec 28 2015, 04:58 PM
I was just looking at the following reference info.
https://mobiloil.com/~/media/amer/us/pvl/fi...specs-guide.pdfLooks like 15W-50 is rated for flat tappet applications.
Thanks for the assist.
Cracker
Dec 28 2015, 09:10 PM
FWIW: I run Mobile One 15-50 in my LS 914 and my D-Sportsracer. It is cheap enough that I only run two-weekends with it and start afresh.
Tony
Randal
Dec 29 2015, 10:19 AM
QUOTE(Cracker @ Dec 28 2015, 07:10 PM)
Tony
Trusting you had a Merry Christmas and best wishes for the 2016 New Year!
You need to post some pictures of your D Sport on here as well. Video also welcome.
FastFroggy
Dec 29 2015, 10:23 AM
Still on subject: has anyone tried 0w50 Mobil One Race Oil in a 4cylinder? Seems too thin. Just figured to ask. ZDDP is really high.
Thanks
kupcar
Dec 29 2015, 01:57 PM
Froggy, if you like Mobile 1, then my recommendation would be Mobile V-Twin. The zinc levels are very good. I have also used Valvoline VR-1. Also good zinc numbers and a bit easier on the pocketbook than the Mobile. For the gearbox, Swepco 201. Hope that helps.
Randal
Dec 29 2015, 02:50 PM
QUOTE(kupcar @ Dec 29 2015, 11:57 AM)
That's the oil that Mat Lowrance recommends, i.e., Mobile V-Twin. He's a big time engine builder in Reno.
jmill
Dec 30 2015, 01:52 PM
QUOTE(brant @ Dec 28 2015, 09:25 AM)
Unfortunately, I grenaded an engine with a high lift flat tappet cam before I knew the additive was removed.
jmill
Dec 30 2015, 02:07 PM
Mobil 1 has it but at about half the levels of V twin or their racing oils.
FastFroggy
Dec 31 2015, 07:15 AM
Well understand ZDDP is needed. Question is how much. 15W-50 is listed at 1200phos and 1300zinc... I am nervous about it but the Mobil 1 guide does say "HT/HS applications, Racing and Flat tappet applications.". Question is how much is necessary? I filled with 15w-50 for now. Doing my first once thru on all systems. Will look to change probably after one or two events anyway.
Cracker
Dec 31 2015, 08:02 AM
Kermit: Is this a 2, 4, 6, or 8 cylinder?
Randal: Here you go...this car has a full CF body (2 clips) and Stohr wing. Lots of fun...NOW, back to the oily discussion. This is more fun though...
Tony
Click to view attachmentClick to view attachmentClick to view attachmentClick to view attachmentClick to view attachmentClick to view attachmentClick to view attachmentQUOTE(Randal @ Dec 29 2015, 11:19 AM)
Tony
Randal
Dec 31 2015, 12:40 PM
Nice chassis
but keeping on topic, which oil you running in that GSXR?
Oh, you have tunnels on the DSR, very impressive!
campbellcj
Dec 31 2015, 09:13 PM
My builder also uses the V-Twin. I've used that, and Brad Penn.
eimc
Jan 1 2016, 09:37 AM
QUOTE(FastFroggy @ Dec 28 2015, 06:48 AM)
Thanks
Use Sweepco in trans and never have to worry
brant
Jan 1 2016, 10:40 AM
Change motor oil after every race.
I'm currently using redline (lt wt shockproof) in the trans and having great results
PotterPorsche
Mar 7 2016, 10:14 PM
Brad penn 10/30 20/50 up to you, high ziinc content.
http://www.ebay.com/itm/Brad-Penn-Grade-1-...%3D200591297651$6.50 a quart shipped.
FastFroggy
Mar 13 2016, 05:25 PM
thanks.... great price too!
