Another Wiring Question, Where does This Wire Go? |
motorvated |
Dec 28 2015, 02:26 PM
Member Group: Members Posts: 279 Joined: 13-February 13 From: Colorado Member No.: 15,519 Region Association: Rocky Mountains |
"Brown" wire with ring connector that passes through rear tin grommet on driver's side rear of engine compartment. Is it a hot lead from the alternator to the starter which goes on the same post as the main wire from the battery positive? 1972 with a '75 1.8 L-Jet, no relay board, and a most terrible re-wiring job from new fuse box under dash. This wire looks to be original and splits off a larger bundle of wires that may go down to the alternator. Here's the pic.
ejm |
Dec 28 2015, 06:18 PM
I can see the light at the end of the tunnel Group: Members Posts: 2,692 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
motorvated |
Dec 28 2015, 07:23 PM
Is it a hot lead from the alternator to the starter which goes on the same post as the main wire from the battery positive? Yes Thank You Ed. I might have more questions as I attempt to reconnect everything electrical now that I have the car out from under the jack stands.....at last. Dropped her on the ground on Christmas Day as a present to myself. Mike S. |
Lo-Fi Version | Time is now: 19th May 2024 - 10:41 AM |
