Thread size of the rear trunk lock nut |
Harpo |
Dec 28 2015, 04:03 PM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
I sent my rear trunk lock mechanism some where along the way the threads were damaged. I have tried cleaning them up with a file but no luck. Next I intend to buy a nut and cut it in half clamp it tight then remove the nut.
The problem is that I don't know what size nut to buy Thanks David |
tweet |
Dec 28 2015, 04:26 PM
Member Group: Members Posts: 200 Joined: 25-February 13 From: South Florida Member No.: 15,579 Region Association: South East States |
Hello David,
We will send you one. Dan & Alicia |
rgalla9146 |
Dec 28 2015, 05:09 PM
Advanced Member Group: Members Posts: 4,560 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
I sent my rear trunk lock mechanism some where along the way the threads were damaged. I have tried cleaning them up with a file but no luck. Next I intend to buy a nut and cut it in half clamp it tight then remove the nut. The problem is that I don't know what size nut to buy Thanks David Hi David The nut is 32mm....you need a standard socket, not an impact. The damaged threads are likely only on the cylinder rather than the nut......unless you forced it. What kind of file did you use ? There is a special file just for outside threads. Ask for a thread file in your FLAPS. The thread on your lock cyl. is 1.00 (I just checked) Rory |
GaroldShaffer |
Dec 28 2015, 05:50 PM
You bought another 914? Group: Benefactors Posts: 7,623 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
Hello David, We will send you one. Dan & Alicia I have some also if Dan & Alicia can't help you. Same offer as theirs, just need your address and I will drop in the mail tomorrow. (IMG:style_emoticons/default/beerchug.gif) |
Harpo |
Dec 28 2015, 08:04 PM
Thanks everybody. Yes first I tried the special thread file. Yes a spare nut would be great either Dan or Garold
David Calkins 605 Fernwood rd Royal Oak, Mich 48067 |
tweet |
Dec 28 2015, 08:07 PM
I sent my rear trunk lock mechanism some where along the way the threads were damaged. I have tried cleaning them up with a file but no luck. Next I intend to buy a nut and cut it in half clamp it tight then remove the nut. The problem is that I don't know what size nut to buy Thanks David When you say you sent it somewhere. Was it by chance re-chromed? |
Harpo |
Dec 28 2015, 11:47 PM
No, I had it powder coated
bdstone914 |
Dec 29 2015, 12:29 AM
bdstone914 Group: Members Posts: 4,528 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
GaroldShaffer |
Dec 29 2015, 07:41 AM
Lo-Fi Version | Time is now: 28th May 2024 - 10:52 AM |
