QUOTE(Harpo @ Dec 28 2015, 05:03 PM)
I sent my rear trunk lock mechanism some where along the way the threads were damaged. I have tried cleaning them up with a file but no luck. Next I intend to buy a nut and cut it in half clamp it tight then remove the nut.
The problem is that I don't know what size nut to buy
Thanks
David
Hi David
The nut is 32mm....you need a standard socket, not an impact.
The damaged threads are likely only on the cylinder rather than the nut......unless you forced it.
What kind of file did you use ?
There is a special file just for outside threads.
Ask for a thread file in your FLAPS.
The thread on your lock cyl. is 1.00 (I just checked)
Rory
