1975 Ignition Lock Cylinder Removal |
jkuehn |
Dec 28 2015, 05:45 PM
Newbie Group: Members Posts: 7 Joined: 20-August 07 From: MO Member No.: 8,021 |
I can't for the life of me figure out how to get the ignition tumbler out of the steering column of my 75. I have looked online and the one site i found showed a hole to push in the clip to release it but mine does not have that hole, can someone help as i have it down to just the housing at this point.
914Sixer |
Dec 28 2015, 07:07 PM
75-76 is completely different that 72-74.
76-914 |
Dec 28 2015, 07:41 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,500 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
IIRC and I usually don't, there is a small screw in the back on 75-76 that you remove 1st. (IMG:style_emoticons/default/beerchug.gif)
ejm |
Dec 28 2015, 07:51 PM
I can see the light at the end of the tunnel Group: Members Posts: 2,691 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
I can't for the life of me figure out how to get the ignition tumbler out of the steering column of my 75. I have looked online and the one site i found showed a hole to push in the clip to release it but mine does not have that hole, can someone help as i have it down to just the housing at this point. If there is no hole you'll have to drill one. If the hole is there it would be under a small removable steel plate that fits into a slot in the housing. Use another lock cyl to locate how far down to drill the hole. |
tweet |
Dec 28 2015, 08:14 PM
Member Group: Members Posts: 200 Joined: 25-February 13 From: South Florida Member No.: 15,579 Region Association: South East States |
In 75-76 only some of the steering lock housings came with the hole that you need. The hole allows you to depress the spring clip on the ignition lock to then pull it out. Drilling the hole is possible if it is not present. The difficulty lies in getting the correct angle to drill in the correct spot with the steering shaft in place. It can be done with a Dremel flex shaft and small bit; requires patience.
pdlightning |
Dec 28 2015, 11:33 PM
Member Group: Members Posts: 207 Joined: 4-February 11 From: Santa Clarita Member No.: 12,660 Region Association: Southern California |
In 75-76 only some of the steering lock housings came with the hole that you need. The hole allows you to depress the spring clip on the ignition lock to then pull it out. Drilling the hole is possible if it is not present. The difficulty lies in getting the correct angle to drill in the correct spot with the steering shaft in place. It can be done with a Dremel flex shaft and small bit; requires patience. How does the early 70-71 cylinders get removed? I heard they are different also! |
ejm |
Dec 29 2015, 08:10 AM
Dec 29 2015, 10:19 AM
Given this is just a spring clip, can the cylinder be removed by force?
Can one screw in a decent sheet metal screw into the lock and pull it out using a dent puller? Seems the spring would eventually lose. |
barefoot |
Dec 29 2015, 06:53 PM
Senior Member Group: Members Posts: 1,273 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
I can't for the life of me figure out how to get the ignition tumbler out of the steering column of my 75. I have looked online and the one site i found showed a hole to push in the clip to release it but mine does not have that hole, can someone help as i have it down to just the housing at this point. Somewhere in these threads is a complete description of the technique. I can't find it just now, but had saved this photo, worked for me. |
jkuehn |
Dec 30 2015, 12:26 PM
I can't for the life of me figure out how to get the ignition tumbler out of the steering column of my 75. I have looked online and the one site i found showed a hole to push in the clip to release it but mine does not have that hole, can someone help as i have it down to just the housing at this point. Somewhere in these threads is a complete description of the technique. I can't find it just now, but had saved this photo, worked for me. Which one in the pic worked for you the one on the right or left? |
ejm |
Dec 30 2015, 01:40 PM
The factory drilled ones I've seen had the hole in the slot. The groove in the lock cyl is over 1/2" long. With a thin pick you could most likely release it drilling outside the slot. Drilling the correct distance down from the edge of the housing is more important since the tab is less than 3/16 wide.
tweet |
Dec 30 2015, 06:52 PM
The pictures are indicating the following:
first - the metal plate that covers the hole second - orientation of spring clip on ignition lock as it relates to the access hole; as you can see the apex of the spring clip lines up with the hole when fully seated in steering lock third - metal plate removed on a factory pre-drilled hole fourth - hole manually drilled on a steering lock that was not present originally fifth - you can see the apex of the spring clip lines up with the hole once it is fully seated in steering lock sixth - you need to drill the hole about 12-13 mm from the very edge of the steering lock housing so that the hole is centered over the spring clip---don't go too deep or you will drill through the spring clip Attached thumbnail(s) |
Tz Toy |
Aug 10 2020, 10:20 PM
Newbie Group: Members Posts: 6 Joined: 15-June 20 From: Seattle'ish WA Member No.: 24,382 Region Association: Pacific Northwest |
The pictures are indicating the following: first - the metal plate that covers the hole second - orientation of spring clip on ignition lock as it relates to the access hole; as you can see the apex of the spring clip lines up with the hole when fully seated in steering lock third - metal plate removed on a factory pre-drilled hole fourth - hole manually drilled on a steering lock that was not present originally fifth - you can see the apex of the spring clip lines up with the hole once it is fully seated in steering lock sixth - you need to drill the hole about 12-13 mm from the very edge of the steering lock housing so that the hole is centered over the spring clip---don't go too deep or you will drill through the spring clip Thanks for the pics. Never would have figured out how to pull tumbler without them. |
Lo-Fi Version | Time is now: 14th May 2024 - 07:23 PM |
