jkuehn
Dec 28 2015, 05:45 PM
I can't for the life of me figure out how to get the ignition tumbler out of the steering column of my 75. I have looked online and the one site i found showed a hole to push in the clip to release it but mine does not have that hole, can someone help as i have it down to just the housing at this point.
914Sixer
Dec 28 2015, 07:07 PM
75-76 is completely different that 72-74.
76-914
Dec 28 2015, 07:41 PM
IIRC and I usually don't, there is a small screw in the back on 75-76 that you remove 1st.
ejm
Dec 28 2015, 07:51 PM
QUOTE(jkuehn @ Dec 28 2015, 06:45 PM)
If there is no hole you'll have to drill one. If the hole is there it would be under a small removable steel plate that fits into a slot in the housing. Use another lock cyl to locate how far down to drill the hole.
tweet
Dec 28 2015, 08:14 PM
In 75-76 only some of the steering lock housings came with the hole that you need. The hole allows you to depress the spring clip on the ignition lock to then pull it out. Drilling the hole is possible if it is not present. The difficulty lies in getting the correct angle to drill in the correct spot with the steering shaft in place. It can be done with a Dremel flex shaft and small bit; requires patience.
pdlightning
Dec 28 2015, 11:33 PM
QUOTE(tweet @ Dec 28 2015, 06:14 PM)
How does the early 70-71 cylinders get removed? I heard they are different also!
ejm
Dec 29 2015, 08:10 AM
QUOTE(pdlightning @ Dec 29 2015, 12:33 AM)
It has a similar spring tab that requires drilling a hole
r_towle
Dec 29 2015, 10:19 AM
Given this is just a spring clip, can the cylinder be removed by force?
Can one screw in a decent sheet metal screw into the lock and pull it out using a dent puller?
Seems the spring would eventually lose.
barefoot
Dec 29 2015, 06:53 PM
Somewhere in these threads is a complete description of the technique.
I can't find it just now, but had saved this photo, worked for me.
jkuehn
Dec 30 2015, 12:26 PM
QUOTE(barefoot @ Dec 29 2015, 06:53 PM)
Click to view attachmentWhich one in the pic worked for you the one on the right or left?
ejm
Dec 30 2015, 01:40 PM
The factory drilled ones I've seen had the hole in the slot. The groove in the lock cyl is over 1/2" long. With a thin pick you could most likely release it drilling outside the slot. Drilling the correct distance down from the edge of the housing is more important since the tab is less than 3/16 wide.
tweet
Dec 30 2015, 06:52 PM
The pictures are indicating the following:
first - the metal plate that covers the hole
second - orientation of spring clip on ignition lock as it relates to the access hole; as you can see the apex of the spring clip lines up with the hole when fully seated in steering lock
third - metal plate removed on a factory pre-drilled hole
fourth - hole manually drilled on a steering lock that was not present originally
fifth - you can see the apex of the spring clip lines up with the hole once it is fully seated in steering lock
sixth - you need to drill the hole about 12-13 mm from the very edge of the steering lock housing so that the hole is centered over the spring clip---don't go too deep or you will drill through the spring clip
Tz Toy
Aug 10 2020, 10:20 PM
QUOTE(tweet @ Dec 30 2015, 05:52 PM)
Thanks for the pics. Never would have figured out how to pull tumbler without them.
