Finishing Fiberglass / Bondo ? |
joea9146 |
Mar 15 2005, 06:22 PM
Senior Member Group: Members Posts: 663 Joined: 10-February 03 From: Denver, NC Member No.: 283 Region Association: None |
I have a small front valance lip spoiler that I am creating with some layed up fiberglass sheets and resin.
When I am done can I bondo over the fiberglass as a finish coat to blend everything together. How do you finish off the Glass when u are done ? |
Racing916 |
Mar 15 2005, 07:09 PM
Member Group: Members Posts: 341 Joined: 16-October 04 From: Binghamton, NY Member No.: 2,959 Region Association: North East States |
I would look at using some duraglass, which is a bondo and fiberglass mixture that they sell at body shops. This works great, It makes a better bond, and it is a lot harder material. After that I would trow some bondo on it to really smooth it out, and lastly some glaze. I used this technigue for matiching the front 916 bumper to the 916 flares.
Kargeek |
Mar 15 2005, 07:12 PM
Senior Member Group: Members Posts: 555 Joined: 14-March 03 From: Orange, CA Member No.: 430 |
Depending on how smooth your finished fiberglass is you can spray gel coat. However you will probably have multiple low spots so, spread a thin layer of bondo, block sand level then follow up with a high build catalized primer and block out some more. I used to do custom body work on Corvettes- I cut up a few when they were not worth what they are today. DH
URY914 |
Mar 15 2005, 08:05 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,693 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Lo-Fi Version | Time is now: 19th May 2024 - 07:49 AM |
