joea9146
Mar 15 2005, 06:22 PM
I have a small front valance lip spoiler that I am creating with some layed up fiberglass sheets and resin.
When I am done can I bondo over the fiberglass as a finish coat to blend everything together.
How do you finish off the Glass when u are done ?
Racing916
Mar 15 2005, 07:09 PM
I would look at using some duraglass, which is a bondo and fiberglass mixture that they sell at body shops. This works great, It makes a better bond, and it is a lot harder material. After that I would trow some bondo on it to really smooth it out, and lastly some glaze. I used this technigue for matiching the front 916 bumper to the 916 flares.
Kargeek
Mar 15 2005, 07:12 PM
Depending on how smooth your finished fiberglass is you can spray gel coat. However you will probably have multiple low spots so, spread a thin layer of bondo, block sand level then follow up with a high build catalized primer and block out some more. I used to do custom body work on Corvettes- I cut up a few when they were not worth what they are today. DH
URY914
Mar 15 2005, 08:05 PM
what they said.
Paul
