/6 Oil Problem, too much oil in the engine ?? |
914Timo |
Jun 13 2003, 03:00 AM
******* Group: Members Posts: 743 Joined: 13-January 03 From: Finland Member No.: 137 Region Association: Europe |
Hopefully someone could hepl me.... (IMG:style_emoticons/default/clover.gif)
Where is the promblem ?? When I start my 3.0L six, it blows big smoke cloud. (IMG:style_emoticons/default/fighting19.gif) Yesterday I opened the right side valve cover. There came out about 3 liter oil (IMG:style_emoticons/default/sad2.gif) Before that the engine had been not running about 6 days. (IMG:style_emoticons/default/sad.gif) Is it so, that the oil pump let the oil drain from the tank to the oilpan ?? Is there somewhere some kind of back-pressure valve, or should the toleraces in the oil pump be so tight, that no oil can go through it?? Should the oil pump be fluid-tight when the engine doesnt run ??? (IMG:style_emoticons/default/confused24.gif) Or, is it normal that you find your oils in the engine after couple of days ?? How is it ?? Any experiences ?? Any advices ?? (IMG:style_emoticons/default/unsure.gif) Should I chance new valve steams ?? (IMG:style_emoticons/default/smash.gif) Or pistons and cylinders... (IMG:style_emoticons/default/hanged.gif) |
Jeroen |
Jun 13 2003, 07:37 AM
914 Guru Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
Timo,
Dunno, maybe you worry too much. Smoke on start-up is very common and nothing to worry about It's because of the flat 6 configuration... since the cilinders are positioned horizontally, oil seeps past the rings and gets into the combustion chamber when the car isn't running. This (very small amount) of oil is burned on start up. If it keeps smoking, then there is a problem ofcourse. Worn out valvestems will only smoke up on accelleration or decelleration (I always forget which one (IMG:style_emoticons/default/wacko.gif) ) cheers, Jeroen |
Lo-Fi Version | Time is now: 30th May 2024 - 12:23 AM |
