/6 Oil Problem, too much oil in the engine ?? |
914Timo |
Jun 13 2003, 03:00 AM
******* Group: Members Posts: 743 Joined: 13-January 03 From: Finland Member No.: 137 Region Association: Europe |
Hopefully someone could hepl me.... (IMG:style_emoticons/default/clover.gif)
Where is the promblem ?? When I start my 3.0L six, it blows big smoke cloud. (IMG:style_emoticons/default/fighting19.gif) Yesterday I opened the right side valve cover. There came out about 3 liter oil (IMG:style_emoticons/default/sad2.gif) Before that the engine had been not running about 6 days. (IMG:style_emoticons/default/sad.gif) Is it so, that the oil pump let the oil drain from the tank to the oilpan ?? Is there somewhere some kind of back-pressure valve, or should the toleraces in the oil pump be so tight, that no oil can go through it?? Should the oil pump be fluid-tight when the engine doesnt run ??? (IMG:style_emoticons/default/confused24.gif) Or, is it normal that you find your oils in the engine after couple of days ?? How is it ?? Any experiences ?? Any advices ?? (IMG:style_emoticons/default/unsure.gif) Should I chance new valve steams ?? (IMG:style_emoticons/default/smash.gif) Or pistons and cylinders... (IMG:style_emoticons/default/hanged.gif) |
joea9146 |
Jun 13 2003, 08:33 AM
Senior Member Group: Members Posts: 663 Joined: 10-February 03 From: Denver, NC Member No.: 283 Region Association: None |
Taking the valve cover off and having oil dump out is normal.
The oil does drain back into the motor. Finding oil in the exhaust port is not ok. Could be bad valve guides or bad valve seals. How much smoke to you get on startup ??? How much oil did you put in the motor .... are you running CIS is the oil in the Intake Air box ? |
Lo-Fi Version | Time is now: 19th May 2024 - 05:13 PM |
