Will to 5" auto meter gauges fit Side by side in dash |
Gearup |
Jan 4 2016, 10:40 AM
Member Group: Members Posts: 154 Joined: 21-April 15 From: Denver Member No.: 18,660 Region Association: None |
Hey Guys. I have two new 5 inch silver faced Autometer gauges that I was hoping to install in a fabricated piece of aluminum in the dash. Has anyone done that here with success, and if so, did it look good? If not I could drop down to 2 3 3/8. This s a GT V8 build so I'm good with the non OEM
Bills914-4 |
Jan 4 2016, 11:25 AM
Member Group: Members Posts: 310 Joined: 1-March 08 From: suburbs of Miami FL. Member No.: 8,762 Region Association: South East States |
76-914 |
Jan 4 2016, 11:31 AM
easily done........... http://www.914world.com/bbs2/index.php?sho...1776&st=400 If you don't flange the new holes then use urethane foam with the gages set in the faceplate, covered in saranwrap but not installed on the car. This gives the gages support. (IMG:style_emoticons/default/beerchug.gif)
Gearup |
Jan 4 2016, 01:43 PM
Thank you guys. Those are the gauges I am using. Bill, did you flange the holes and if not how did you secure the gauge in the hole. Thanks again, Brett
got914? |
Jan 4 2016, 02:42 PM
Member Group: Members Posts: 133 Joined: 8-October 14 From: Niagara Member No.: 17,993 Region Association: None |
What speedometer did you use and how did you make it work ? Electric im assuming ?
76-914 |
Jan 5 2016, 10:40 AM
Just saw that I gave you the wrong segment. Go to post #325 to make another face plate if you haven't already. (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 17th May 2024 - 04:41 PM |
