Gearup
Jan 4 2016, 10:40 AM
Hey Guys. I have two new 5 inch silver faced Autometer gauges that I was hoping to install in a fabricated piece of aluminum in the dash. Has anyone done that here with success, and if so, did it look good? If not I could drop down to 2 3 3/8. This s a GT V8 build so I'm good with the non OEM
Bills914-4
Jan 4 2016, 11:25 AM
Here's a few pic's of mine , just so you get an idea , be careful of the possible blind
spot from the steering wheel, hope this helps Bill D.
this is older one
Click to view attachmentnewer one
Jan 4 2016, 11:31 AM
easily done...........
http://www.914world.com/bbs2/index.php?sho...1776&st=400 If you don't flange the new holes then use urethane foam with the gages set in the faceplate, covered in saranwrap but not installed on the car. This gives the gages support.
Gearup
Jan 4 2016, 01:43 PM
Thank you guys. Those are the gauges I am using. Bill, did you flange the holes and if not how did you secure the gauge in the hole. Thanks again, Brett
got914?
Jan 4 2016, 02:42 PM
What speedometer did you use and how did you make it work ? Electric im assuming ?
76-914
Jan 5 2016, 10:40 AM
Just saw that I gave you the wrong segment. Go to post #325 to make another face plate if you haven't already.
