Steering rack rebuild, seal and bearing numbers |
Olympic 914 |
Jan 8 2016, 09:09 AM
Group: Members Posts: 1,663 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
Thought I would install my Turbo tie rod ends and found that one of the rack end bushings had stuck to the rack and pushed it out. ( probably during storage )
I found a rack rebuild thread by Wes V http://www.914world.com/bbs2/index.php?showtopic=95747 But it seems his rack is different than mine. his is a 75 mine is a 73 . I didn't know they changed them. So it looks like I will have to disassemble my rack and clean up / polish the rack rod. problem is I can't seem to find a number for the seal. Part #10 in diagram Also the 911 rack ( and later 914 rack ? ) has a needle bearing at the top whereas, it looks like the 73 rack has caged ball bearings top and bottom. My rack part number is 914.347.014.00 I haven't disassembled mine yet. Does anyone have part numbers for the bearings and the seal? are the caged rollers the same number as in the 911 rack? # 6202. and if I can't find the seal could I just go with a sealed 6202 bearing (if available) on the top and skip the #10 seal? I put PB blaster on the stuck end bushing last night and will work on it later today. |
Olympic 914 |
Feb 5 2016, 08:04 PM
Well finished up the steering rack.
Turns out the end bushings are really NLA... managed to save mine. put a little heat on the rack and with some more PB blaster I got them to move. then shined the rack up with some fine emery cloth on the lathe. Ready for the new bearings.. and these are the bearings that are used . FAG 16002 and the seal is a 40x28x7 single lip SKF 564085 if any one is thinking about doing this, it really is not a hard job. little trick getting out the lower bearing but other than that its a straight forward job. good idea to mark the rack and housing with a dot of paint so they go back together the same way. Done. |
Lo-Fi Version | Time is now: 13th May 2024 - 08:01 AM |
