Steering rack rebuild, seal and bearing numbers |
Olympic 914 |
Jan 8 2016, 09:09 AM
Group: Members Posts: 1,663 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
Thought I would install my Turbo tie rod ends and found that one of the rack end bushings had stuck to the rack and pushed it out. ( probably during storage )
I found a rack rebuild thread by Wes V http://www.914world.com/bbs2/index.php?showtopic=95747 But it seems his rack is different than mine. his is a 75 mine is a 73 . I didn't know they changed them. So it looks like I will have to disassemble my rack and clean up / polish the rack rod. problem is I can't seem to find a number for the seal. Part #10 in diagram Also the 911 rack ( and later 914 rack ? ) has a needle bearing at the top whereas, it looks like the 73 rack has caged ball bearings top and bottom. My rack part number is 914.347.014.00 I haven't disassembled mine yet. Does anyone have part numbers for the bearings and the seal? are the caged rollers the same number as in the 911 rack? # 6202. and if I can't find the seal could I just go with a sealed 6202 bearing (if available) on the top and skip the #10 seal? I put PB blaster on the stuck end bushing last night and will work on it later today. |
Mikey914 |
Dec 29 2018, 09:37 PM
The rubber man Group: Members Posts: 12,659 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
We’ve found 4 different versions of the racks. Currently have all the variations and will be doing a writ up of a rebuild I’m doing Monday. I can rebuild it for you. We also set the correct tension on the unit when Rowe rebuild them.
Many folks think it’s a simple take apart clean up and replace parts but there are a few variables that can affect the quality of the rebuild. |
Luke M |
Jan 1 2019, 08:20 AM
Senior Member Group: Members Posts: 1,371 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
We’ve found 4 different versions of the racks. Currently have all the variations and will be doing a writ up of a rebuild I’m doing Monday. I can rebuild it for you. We also set the correct tension on the unit when Rowe rebuild them. Many folks think it’s a simple take apart clean up and replace parts but there are a few variables that can affect the quality of the rebuild. Hi Mark, I have two steering racks which would need a refresh. One came out of a 71 914-4 (914.347.101.00) and the other out of my factory 6 (7820 900 138). I would need the 6 rack rebuilt for sure. When I removed the rubber boots I could see that grease was getting past the seals at both ends. Do you sell a rebuild kit for the 6 (ZF) rack ? I checked your site but wasn't able to locate a kit. Here's a few pics. Attached image(s) |
Lo-Fi Version | Time is now: 12th May 2024 - 09:14 AM |
