Pulling engine, socket for the CV joint |
jones |
Mar 16 2005, 09:16 PM
Member Group: Members Posts: 126 Joined: 4-March 04 From: Seattle Member No.: 1,751 |
As taken from engine drop procedure. Do I ask my FLAPS counter guy for a 12 mm serrated socket, is that the correct lingo? Do I need to go to a more specialized source? Thanks (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) |
Joe Bob |
Mar 16 2005, 09:20 PM
Triple square
iiibdsiil |
Mar 16 2005, 09:21 PM
Needs Door Locks Group: Members Posts: 605 Joined: 19-November 03 From: Tampa / Boca Raton, FL Member No.: 1,362 |
8 mm tripple square, I think.
Teknon |
Mar 16 2005, 09:39 PM
The more I learn the dumber i think I am Group: Members Posts: 357 Joined: 10-August 04 From: Denver, Colorado Member No.: 2,505 Region Association: Rocky Mountains |
Yeah, It's a 8mm triple square. $4 at NAPA (IMG:http://www.914world.com/bbs2/html/emoticons/smoke.gif)
Joe Ricard |
Mar 16 2005, 09:44 PM
YUP that's what ya need. I put a 8mm box wrench on it and works great for breaking them loose. Better order your new bolts and serrated washers and cv joint gaskets now so they will be ready to go in when the motor is done. |
Mar 16 2005, 10:59 PM
First, check the bolts on your car. Some people have upgraded them with standard Allen-head (hex-shaped hole) bolts. See if you can get an eyeball on the bolts on the outer CV joints, while you're at it. And look at the three bolts that hold the cooling fan onto the fan hub. Those are the three locations that I know of that can use M8 triple square bolts on 914s. If you don't have any in any of those, skip buying the tool.
Note: You may need to clean out the socket in the head of the bolt to really tell which kind of bolt it is!! Bring along some carb cleaner and a rag when you check. As mentioned, you can get the tool from your parts place--or stop into anywhere they know VW Bugs and ask for "the CV joint socket". Bugs used the same fasteners as us--so did early 911s, for that matter. --DD |
Lo-Fi Version | Time is now: 19th May 2024 - 12:34 AM |
