iiibdsiil
Mar 16 2005, 09:21 PM
8 mm tripple square, I think.
Teknon
Mar 16 2005, 09:39 PM
Yeah, It's a 8mm triple square. $4 at NAPA
Dave_Darling
Mar 16 2005, 10:59 PM
First, check the bolts on your car. Some people have upgraded them with standard Allen-head (hex-shaped hole) bolts. See if you can get an eyeball on the bolts on the outer CV joints, while you're at it. And look at the three bolts that hold the cooling fan onto the fan hub. Those are the three locations that I know of that can use M8 triple square bolts on 914s. If you don't have any in any of those, skip buying the tool.
Note: You may need to clean out the socket in the head of the bolt to really tell which kind of bolt it is!! Bring along some carb cleaner and a rag when you check.
As mentioned, you can get the tool from your parts place--or stop into anywhere they know VW Bugs and ask for "the CV joint socket". Bugs used the same fasteners as us--so did early 911s, for that matter.
--DD
