> Fuel Pump Location - Carb Engine, Need to locate Fuel Pump for Carb car
North Coast Jim
post Jan 10 2016, 03:51 PM
Looking for any information about location of the fuel pump for a carb converted 914. Under the gas tank I assume since a low pressure pump needs good head pressure to operate correctly. With that said is there a preferred pump to use. What tubing/hose is everyone using for transiting the tunnel. Braided or a thick walled high pressure rubber fuel line. I've looked for threads within the site but didn't find any although I'm still learning the site. Any help is appreciated
North Coast Jim   Fuel Pump Location - Carb Engine   Jan 10 2016, 03:51 PM
LowBridge   I have stainless steel line and this pump located ...   Jan 10 2016, 03:59 PM
SirAndy   Do yourself a favor and get a rotary pump. The fac...   Jan 10 2016, 05:04 PM
LowBridge   The facet pumps are noisy as hell. haha... that...   Jan 11 2016, 05:48 AM
Gearhead1432   Do yourself a favor and get a rotary pump. The fa...   Jul 10 2017, 06:13 PM
jmill   Rotary pump is internally regulated and pumps way ...   Jan 10 2016, 05:21 PM
somd914   Concur with Sir Andy and jmill. I run this pump a...   Jan 10 2016, 05:55 PM
screenguy914   I've used an Airtex E8016S fuel pump (2.5-4 ps...   Jan 10 2016, 06:26 PM
914Bryan   Buy the whole kit from Tangerine Racing and be don...   Jan 10 2016, 07:12 PM
dlee6204   The fuel pump from CB performance is just a Carter...   Jan 10 2016, 07:46 PM
boxsterfan   I bought a Bosch 69133 2-port pump for my 74 2.0L....   Jan 10 2016, 08:28 PM
Elliot Cannon   I have had this same pump on my car for 12 years. ...   Jan 10 2016, 08:36 PM
02loftsmoor   I have had this same pump on my car for 12 years....   Jan 12 2016, 08:59 PM
Elliot Cannon   I have had this same pump on my car for 12 years...   Jan 12 2016, 10:04 PM
patssle   I have the same CB rotary pump in the front - I pu...   Jan 10 2016, 09:45 PM
RobW   I'm using the pump above as well. On installat...   Jan 11 2016, 09:12 AM
Mark Henry   For a low pressure carb pump it doesn't matter...   Jan 11 2016, 10:39 AM
J P Stein   Sat there & pumped away for 12-15 years.   Jan 11 2016, 10:51 AM
jmill   Sat there & pumped away for 12-15 years. No...   Jan 11 2016, 11:09 AM
J P Stein   Sat there & pumped away for 12-15 years. N...   Jan 12 2016, 09:45 AM
porschetub   X1 on the Carter pump and I didn't pay CB perf...   Jan 12 2016, 10:42 AM
rhodyguy   Using the return line as a wire conduit was VERY c...   Jan 12 2016, 10:54 AM
jmill   The T-4 short, eh?....right. They are such a hig...   Jan 12 2016, 05:35 PM
02loftsmoor   OK thank for the help   Jan 12 2016, 10:41 PM
- Lo-Fi Version Time is now: 13th July 2025 - 10:18 AM
