One more - whos' interested in an early relay cover -Correct for the 6? 914.610.111.13, These are $24 each on GB and will be $36 when done |
Mikey914 |
Jan 11 2016, 01:14 AM
The rubber man Group: Members Posts: 12,667 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Others have made the late style relay cover. It's more of a commercial piece as you can use it on the early. The difference is that the firewall changed because of the seat belt mounts and I'm not sure exactly when this occurred. I know for a fact the 75 and 76 have the sloped relay cover, and the 70-72 should be the early. Somewhere in between there was a transition. I think is was 73? So any info for those whit the cars would help.
I made the early as no one else was doing so, being correct for the 6 means that a correct part is desirable for at least a few folks, so it was a worthwhile endeavor. These will be ready in about 2 weeks. Good news too for those of you that want the late we are working on them but they will follow about a month later. So who wants an early? Attached thumbnail(s) |
Mikey914 |
Jan 11 2016, 01:15 AM
Here's how it compares to the OEM part. Test fit onto the relay board.
Mikey914 |
Jan 11 2016, 01:16 AM
Early VS late. The late style has a slope in it.
JeffBowlsby |
Jan 11 2016, 01:48 AM
914 Wiring Harnesses Group: Members Posts: 8,507 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Got the large rubber band to go with that? (IMG:style_emoticons/default/smile.gif)
pneuhyde |
Jan 11 2016, 03:10 AM
Member Group: Members Posts: 94 Joined: 24-February 05 From: San Leandro, Ca. Member No.: 3,654 Region Association: Pacific Northwest |
I had wandered why the cover i procured never seemed to fit on my 74. Good thing I have upgraded to a 72 so I have a cover now, for it.
(IMG:style_emoticons/default/smile.gif) |
914Next |
Jan 11 2016, 04:44 AM
Senior Member Group: Members Posts: 699 Joined: 28-July 14 From: Ephraim Wisconsin Member No.: 17,695 Region Association: Upper MidWest |
Others have made the late style relay cover. It's more of a commercial piece as you can use it on the early. The difference is that the firewall changed because of the seat belt mounts and I'm not sure exactly when this occurred. I know for a fact the 75 and 76 have the sloped relay cover, and the 70-72 should be the early. Somewhere in between there was a transition. I think is was 73? So any info for those whit the cars would help. I made the early as no one else was doing so, being correct for the 6 means that a correct part is desirable for at least a few folks, so it was a worthwhile endeavor. These will be ready in about 2 weeks. Good news too for those of you that want the late we are working on them but they will follow about a month later. So who wants an early? Mark, my '73 has the later sloped cover. Not sure when they transitioned. |
Mikey914 |
Jan 11 2016, 08:07 AM
This is what I had suspected, the cut off was 72.
sbsix |
Jan 11 2016, 10:31 AM
only the lead dog enjoys a change in scenery... Group: Members Posts: 450 Joined: 10-January 12 From: Santa Barbara, CA Member No.: 13,990 Region Association: Southern California |
Mark, I'm in for an early one.
rick 918-S |
Jan 11 2016, 10:57 AM
Hey nice rack! -Celette Group: Members Posts: 20,458 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
I'm in for one. Learn something new everyday. (IMG:style_emoticons/default/shades.gif) Show me this rubber binder. Never seen one.. (IMG:style_emoticons/default/confused24.gif) |
Jan 11 2016, 11:44 AM
The inertia-reel seat belts were either an option in 72, or switched over partway through the model year. It is therefore most likely that the change to the relay board cover happened somewhere in the 72 model year.
Is this cover suitable for an original Six? I know their relay board is very different from the 914-4 versions; not sure about the sizes and such. --DD |
Kansas 914 |
Jan 11 2016, 12:11 PM
The inertia-reel seat belts were either an option in 72, or switched over partway through the model year. It is therefore most likely that the change to the relay board cover happened somewhere in the 72 model year. --DD (IMG:style_emoticons/default/agree.gif) My early '72 did not have retractable belts and the relay cover had the post and knurled knob. |
Mikey914 |
Anyone go a picture of a 6 board? I would think it may be but not sure.
JeffBowlsby |
Jan 11 2016, 05:03 PM
I'm in for one. Learn something new everyday. (IMG:style_emoticons/default/shades.gif) Show me this rubber binder. Never seen one.. (IMG:style_emoticons/default/confused24.gif) http://c767170.r70.cf2.rackcdn.com/G99970144540.jpg It fits at the notch in the upper rib of the cover. |
fixer34 |
Jan 11 2016, 07:06 PM
Senior Member Group: Members Posts: 1,085 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest |
Mikey914 |
Jan 12 2016, 12:41 PM
I'm in for one. Learn something new everyday. (IMG:style_emoticons/default/shades.gif) Show me this rubber binder. Never seen one.. (IMG:style_emoticons/default/confused24.gif) http://c767170.r70.cf2.rackcdn.com/G99970144540.jpg It fits at the notch in the upper rib of the cover. I'm sure I can make one. Was the original orange? |
Mikey914 |
Jan 12 2016, 12:42 PM
porschetub |
Jan 14 2016, 02:56 PM
Anyone go a picture of a 6 board? I would think it may be but not sure. I can go take one if needed. Think I may have my original cover around someplace also. That would be awesome My cover is the non angled one and it won't fit without unscrewing the relay board. Its a pain basically ,my car is a 74 but appears the later angled on is the one I need...confused on this ,can you or others comment? Would certainly be interested when your start production of them. |
Jan 14 2016, 06:20 PM
Your car is mid-72 or later. (Because 74 is after mid-72.) So you have the "inertia-reel" seatbelts--the ones you can pull out and will roll up (in theory!!) when you let go. So you have the modified firewall to make room for those, so you need the late angled cover.
Good enough comment? (IMG:style_emoticons/default/wink.gif) --DD |
pete000 |
Jan 14 2016, 06:25 PM
Count me in for one.
fixer34 |
Jan 14 2016, 10:26 PM
Lo-Fi Version | Time is now: 16th May 2024 - 04:17 PM |
