Just another 2056 build, Misc Questions |
sdoolin |
Jan 13 2016, 04:29 PM
Member Group: Members Posts: 359 Joined: 1-May 14 From: LouKY Member No.: 17,299 Region Association: None |
Yep, I am building a 2056. Have ordered very nearly a complete 2056 engine kit from Type IV Store (LN Engineering). Some questions (I have searched and read MANY threads)...
I have a "spare" 1976 VW Bus short block (no cyl. heads). Assume this will work for a starting point? Issues with oil dipstick? The bus was an automatic so I assume once I remove the "flex plate" that the flywheel from by 914 engine (in car) will bolt up to the crank without issues? Any issues with engine carrier? The bus used a "moustache bar" for mounting to the frame and I am hoping that the cases from the bus/914 are the same for engine mounting? Will re-use existing Crank/rods New crank/rod bearings Will re-use existing cylinders (overbored) KB 96 mm flat topped pistons with Hastings rings Webcam cam (9130 kit from Type IV Store) Type IV Store pushrods, pushrod ends, parkerized lifters, rocker shafts Type IV Store cam bearings Re-use rockers from bus engine? Not sure about this... HAM (Len Hoffman) RS+ spec cylinder heads New Oil pump from Type IV Store New clutch & pressure plate. Re-use flywheel from 914 engine (in the car) Dellorto Dual 40mm carbs, CB Perf manifolds & linkage SSI heat exchangers & Bursch exhaust New fuel pump - will run return lines (have CFR SS Lines in car now and will re-use) Not sure what dizzy to run? I believe I need to check/verify deck height and valve clearance (I know how, just not positive this is required for a 2056 build). I have read a few threads about "setting" compression ration, but do not understand it yet? Anyone have a compression ratio for dummies guide? Anything else I'm missing? Progress so far... |
stugray |
Mar 11 2016, 07:08 PM
Advanced Member Group: Members Posts: 3,824 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
Right off the top of my head:
You will almost certainly take the case halves apart many times, so dont use any sealant on the mating halves till youre sure. The #1 mistake made is letting the bearings come unseated from the dowel pins that hold the bearings. This results in brand new, ruined bearings. As you torque the sides together rotate the crank & cam they should turn like butter even at full case torque. Once you have the rods attached, be careful when you rotate the assembly and dont let the rods slap on the case. Once you have the jugs on you will be measuring your deck height. I have an old thread where I struggled with this for a long time before getting it right. I'll see if I can dig it up. There are some tools provided by a member on this site (yeahmag) that makes the measurement 'almost' idiot-proof. Here it is: http://www.914world.com/bbs2/index.php?showtopic=196177 |
Lo-Fi Version | Time is now: 18th May 2024 - 05:04 AM |
