Just another 2056 build, Misc Questions |
sdoolin |
Jan 13 2016, 04:29 PM
Member Group: Members Posts: 359 Joined: 1-May 14 From: LouKY Member No.: 17,299 Region Association: None |
Yep, I am building a 2056. Have ordered very nearly a complete 2056 engine kit from Type IV Store (LN Engineering). Some questions (I have searched and read MANY threads)...
I have a "spare" 1976 VW Bus short block (no cyl. heads). Assume this will work for a starting point? Issues with oil dipstick? The bus was an automatic so I assume once I remove the "flex plate" that the flywheel from by 914 engine (in car) will bolt up to the crank without issues? Any issues with engine carrier? The bus used a "moustache bar" for mounting to the frame and I am hoping that the cases from the bus/914 are the same for engine mounting? Will re-use existing Crank/rods New crank/rod bearings Will re-use existing cylinders (overbored) KB 96 mm flat topped pistons with Hastings rings Webcam cam (9130 kit from Type IV Store) Type IV Store pushrods, pushrod ends, parkerized lifters, rocker shafts Type IV Store cam bearings Re-use rockers from bus engine? Not sure about this... HAM (Len Hoffman) RS+ spec cylinder heads New Oil pump from Type IV Store New clutch & pressure plate. Re-use flywheel from 914 engine (in the car) Dellorto Dual 40mm carbs, CB Perf manifolds & linkage SSI heat exchangers & Bursch exhaust New fuel pump - will run return lines (have CFR SS Lines in car now and will re-use) Not sure what dizzy to run? I believe I need to check/verify deck height and valve clearance (I know how, just not positive this is required for a 2056 build). I have read a few threads about "setting" compression ration, but do not understand it yet? Anyone have a compression ratio for dummies guide? Anything else I'm missing? Progress so far... |
sdoolin |
Apr 30 2016, 10:41 AM
Never drop a brand new cylinder (or any other cylinder you might want to use). I turned down 3 of 4 cylinders using my wayoverthetop fixture, then tripped slightly on a dogs leash in my buddy's shop allowing the fourth cylinder to escape my grasp.
Damaged the skirt ever so slightly and it will not slip over my wayoverthetop fixture. Anyone have a single 96mm cylinder laying around that they feel the need to part with? |
wndsrfr |
Apr 30 2016, 07:25 PM
Senior Member Group: Members Posts: 1,429 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
Never drop a brand new cylinder (or any other cylinder you might want to use). Anyone have a single 96mm cylinder laying around that they feel the need to part with? Yep, got a box with 4 of them that may work for you just gathering dust....I'll ship them to you & you can decide to pay whatever is fair IF you can use one & you hang on to the rest for the next unlucky dude. PM me your address-- |
sdoolin |
May 1 2016, 07:38 AM
Never drop a brand new cylinder (or any other cylinder you might want to use). Anyone have a single 96mm cylinder laying around that they feel the need to part with? Yep, got a box with 4 of them that may work for you just gathering dust....I'll ship them to you & you can decide to pay whatever is fair IF you can use one & you hang on to the rest for the next unlucky dude. PM me your address-- I love this place. PM sent wndsrfr. |
Lo-Fi Version | Time is now: 18th May 2024 - 03:42 AM |
