Just another 2056 build, Misc Questions |
sdoolin |
Jan 13 2016, 04:29 PM
Member Group: Members Posts: 359 Joined: 1-May 14 From: LouKY Member No.: 17,299 Region Association: None |
Yep, I am building a 2056. Have ordered very nearly a complete 2056 engine kit from Type IV Store (LN Engineering). Some questions (I have searched and read MANY threads)...
I have a "spare" 1976 VW Bus short block (no cyl. heads). Assume this will work for a starting point? Issues with oil dipstick? The bus was an automatic so I assume once I remove the "flex plate" that the flywheel from by 914 engine (in car) will bolt up to the crank without issues? Any issues with engine carrier? The bus used a "moustache bar" for mounting to the frame and I am hoping that the cases from the bus/914 are the same for engine mounting? Will re-use existing Crank/rods New crank/rod bearings Will re-use existing cylinders (overbored) KB 96 mm flat topped pistons with Hastings rings Webcam cam (9130 kit from Type IV Store) Type IV Store pushrods, pushrod ends, parkerized lifters, rocker shafts Type IV Store cam bearings Re-use rockers from bus engine? Not sure about this... HAM (Len Hoffman) RS+ spec cylinder heads New Oil pump from Type IV Store New clutch & pressure plate. Re-use flywheel from 914 engine (in the car) Dellorto Dual 40mm carbs, CB Perf manifolds & linkage SSI heat exchangers & Bursch exhaust New fuel pump - will run return lines (have CFR SS Lines in car now and will re-use) Not sure what dizzy to run? I believe I need to check/verify deck height and valve clearance (I know how, just not positive this is required for a 2056 build). I have read a few threads about "setting" compression ration, but do not understand it yet? Anyone have a compression ratio for dummies guide? Anything else I'm missing? Progress so far... |
sdoolin |
May 30 2016, 06:49 PM
Finally made a little more progress. My dropped cylinder was able to be repaired (don't ask - but I am comfortable with what was done). So I was able to jig it up into the lathe and remove material from the top of it. Now that all 4 cylinders are the same height, I can move forward.
WNDSRFR - I did not use any of the jugs that you gifted me. I will PayPal you the $15 shipping this week, and will store those jugs in my barn either until the end of time, or until I can pay it forward for someone else to use. You are a scholar and a gentleman (I think). Checking ring end gap ... I think I mentioned earlier I set top ring at .020, second ring at .015. Piston to cylinder clearance left at .002. Installing pistons into jugs... I hate (HATE) these new (to me) spiral-in wrist pin retainers. I hate them I say! |
Lo-Fi Version | Time is now: 23rd May 2024 - 10:02 AM |
