2.0L exhaust advice... |
Cal |
Jan 14 2016, 07:52 PM
Senior Member Group: Members Posts: 615 Joined: 19-November 14 From: Philadelphia Member No.: 18,138 Region Association: North East States |
I'd like to replace my current Bursch exhaust with an original factory unit. Is there a difference between the current Dansk units that are available and the original Leistritz units? Do they sound different.....is one better than another? Are the original Leistritz units like hen's-teeth to find? Any advice would be helpful.
Jan 14 2016, 09:50 PM
Well, you won't find the original and the dansk unit is pretty close to original.
You don't say what motor you have, but the 1.7/1.8 muffler can be replaced with a unique vw bus muffler with a reverse tailpipe. The can be found. The 2.0 liter, buy the dansk. |
ndfrigi |
Jan 14 2016, 09:55 PM
Tom_T |
Jan 15 2016, 02:46 PM
Cal,
CORRECTION: Where I say Bursch below - correct that to Bischoff - they were the other OEM banana maker back in the day - Bursch was aftermarket. Sorry for the brain fart! (IMG:style_emoticons/default/dry.gif) The Dansk is pretty close to the OEM Bursch & Leistritz "Banana" mufflers - with the added nicer looking chrome tailpipe (IMHO) - which you'd have to buy the extra Porsche chrome tailpipe cover piece for that look back in the day. There are some few Leistritz & Burcsh NOS ones which come up occasionally, & some decent condition used ones which can be restored. BTW - while you're working on your 2L's exhaust system, also check the HE (factory is NLA & hens teeth), so pressure test your HE's & if rusty or leaking, then look to new SS HE's - which Dansk sells & maybe SSI here in the USA as well (I'm not sure if Dansk bought SSI or just sells their current production). Used SSIs can also be found around & are usually in good condition, but they too should be pressure checked to make sure there is no exhaust getting into the heated air circuit to the cabin. Those pix above are of a 1.7/1.8 L Bus muffler 7 not applicable to your 2L (except the 2L Dansk "Banana" pic). PS - Porsche also offered a freer flowing "Sport" version of the "Banana" by Leistritz & Bursch (only way to tell is the p/n from an old parts catalog, since new ones drop the NLA parts). Occasionally you come across one of those. A few years back I found & bought a Leistriz NOS bsanana FS on here, but I still don't have the p/n to tell if it's a regular or sport flavor - either way it works & looks correct. Otherwise, I was going the Dansk route. Good Luck! (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
Lo-Fi Version | Time is now: 17th May 2024 - 05:26 PM |
