73 914 help, New to Porsche new help on value |
tmacdonald1 |
Jan 23 2016, 11:28 PM
Newbie Group: Members Posts: 10 Joined: 23-January 16 From: Alberta Canada Member No.: 19,592 Region Association: None |
I was contacted by a guy who has a 73 914 that he is thinking about selling. I know VWs but nothing about Porsche. What is the trouble areas of the car? He said it is a Cali car with 0 rust. Its had 1 repaint in the past. He said it has a type 4 1.7 FI in it. Here are some pics. Please if I could get a value of what I should pay and anything that might not look correct would be greatly appreciated.
[attachmentid=537 585][attachmentid =537589] (IMG:style_emoticons/default/pray.gif) Attached image(s) |
Bruce Hinds |
Jan 23 2016, 11:58 PM
V-8 madness Group: Members Posts: 733 Joined: 27-December 06 From: Port Orchard, WA Member No.: 7,391 Region Association: Pacific Northwest |
Really nice - I want it.
tmacdonald1 |
Jan 24 2016, 12:00 AM
Any idea of a fair value on it? He said $12000
iankarr |
Jan 24 2016, 12:01 AM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,473 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Welcome!
The first thing to keep in mind is that "zero rust" is a dream. Unless your car has had a nut and bolt restoration, you can be sure that there's some rust lurking under the blue paint. Of course, being a west coast car, there should be less rust than one from the northeast, but there's always more than you expect. The main areas to check out are: 1) The longitudinals ("Longs")' which can only really be examined by removing the rocker covers. This isn't usually a big deal...either a few screws or rivets or both. Definitely check before buying. The longs can rust from the inside out. 2) The "hell hole" under the battery tray. Check to make sure that there's no rust, which can eat through the frame and creat a catastrophic situation. 3) The floor pans. Check under the car and under the carpet. Moisture can get between the pans and underlayment, eating away at the floor. 4) Front and rear trunks. In the rear, check the area where the trunk pan meets the back. Take the car for a drive and make sure you can downshift into 1st and 2nd gears without grinding. Check for oil drips. Ask to see the service records. Otherwise, your car has some obvious mods... Black door handles, a rear spoiler, subwoofer instead of a center gauge console, sail panel delete, chrome trim painted body color, etc. I'd guess the dash pad has some cracks since there's a topper on it. I'm sure the rest of the gang will notice more. Good luck! |
tmacdonald1 |
Jan 24 2016, 12:11 AM
deleted pics
tmacdonald1 |
Jan 24 2016, 12:27 AM
Welcome! The first thing to keep in mind is that "zero rust" is a dream. Unless your car has had a nut and bolt restoration, you can be sure that there's some rust lurking under the blue paint. Of course, being a west coast car, there should be less rust than one from the northeast, but there's always more than you expect. The main areas to check out are: 1) The longitudinals ("Longs")' which can only really be examined by removing the rocker covers. This isn't usually a big deal...either a few screws or rivets or both. Definitely check before buying. The longs can rust from the inside out. 2) The "hell hole" under the battery tray. Check to make sure that there's no rust, which can eat through the frame and creat a catastrophic situation. 3) The floor pans. Check under the car and under the carpet. Moisture can get between the pans and underlayment, eating away at the floor. 4) Front and rear trunks. In the rear, check the area where the trunk pan meets the back. Take the car for a drive and make sure you can downshift into 1st and 2nd gears without grinding. Check for oil drips. Ask to see the service records. Otherwise, your car has some obvious mods... Black door handles, a rear spoiler, subwoofer instead of a center gauge console, sail panel delete, chrome trim painted body color, etc. I'd guess the dash pad has some cracks since there's a topper on it. I'm sure the rest of the gang will notice more. Good luck! The owner just assured me that all the areas 1-4 on this list are good and again said there is not a spot of rust on it |
iwanta914-6 |
Jan 24 2016, 12:46 AM
Senior Member Group: Members Posts: 718 Joined: 26-June 09 From: Minnesota Member No.: 10,510 Region Association: None |
$12K Canadian is a steal.
You really should not have shown the owner's info like that though. Someone will likely call him and buy it out from under you (IMG:style_emoticons/default/wink.gif) |
thieuster |
Jan 24 2016, 04:13 AM
Member Group: Members Posts: 447 Joined: 31-January 15 From: 275 mls NW from Stuttgart. Member No.: 18,384 Region Association: Europe |
Obviously a car that had a caring owner!
Above, there the rocker covers were mentioned. Self tapping screws or new rivets are a good sign: it shows that they were removed not long ago. Again, all 4 points mentioned above need to be checked by yourself! There are tons of pics on the forum where to look. At least, take a strong magnet and a strong lamp when you exam these points. I really hope this turns out okay. From the pics it looks like a nice car with lots of potential for troublefree miles! Menno EDIT: can't comment on the price; prices are a lot higher overhere in Europe. M. |
injunmort |
Jan 24 2016, 05:54 AM
Senior Member Group: Members Posts: 1,024 Joined: 12-April 10 From: sugarloaf ny Member No.: 11,604 Region Association: North East States |
the car is worth $5.00.
Wdunster |
Jan 24 2016, 07:26 AM
Panel beater Group: Members Posts: 172 Joined: 10-June 14 From: Monroe,nc Member No.: 17,469 Region Association: South East States |
If the car is in the condition he says it it and you really want the car then make him an offer. The prices of a good example of a 914 with the factory fuel system in place are going up. The 1.7 wasn't as desire able as the 2.0 but the fun factor is till there. Looking at the pictures it looks like a great car even if it needs a little work. Estimating the price of these cars is very subjective. It is worth what someone is willing to pay for it. If you do get it you will be hooked and turn into one of us. Go get it and jump in!
Bill (IMG:style_emoticons/default/driving-girl.gif) (IMG:style_emoticons/default/driving.gif) |
iankarr |
Jan 24 2016, 08:00 AM
Maintenance records are a good sign. When you take the car for a test drive, make sure the vibration the owner was trying to fix is gone. Also check the exhaust for oil and look at the underside to make sure the tubes aren't still leaking.
DEFINITELY EYEBALL ALL MAIN RUST AREAS YOURSELF! This site has too many stories of people finding out later that they're looking at thousands in repairs. It's not a matter of trust...the owner may not even be aware. I can't stress this enough. You can't spell "trust" without "rust"! That said, if the car really is as described, 12K Canadian isn't crazy. 73 is the most desirable year, but the 1.7 doesn't fetch nearly what a 2.0 would. Check the "sold" listings on eBay and you'll have a sense of where the market is. I'd make a cash offer of 8 and negotiate from there. |
rhodyguy |
Jan 24 2016, 08:35 AM
The owner is tired of throwing thousands of loonies at the car. Worried about a bouncing speedo needle. (IMG:style_emoticons/default/unsure.gif) (IMG:style_emoticons/default/wacko.gif) WTF. Disregard the mileage reading. +100k at a minimum. Pretty pictures but they really don't tell much. If you don't know your way around 914s look for someone or someplace to do a comprehensive pre-purchase inspection. Rocker covers need to come off. Period.
iankarr |
Jan 24 2016, 08:38 AM
+1 totally agree.
tmacdonald1 |
Jan 24 2016, 08:57 AM
$12K Canadian is a steal. You really should not have shown the owner's info like that though. Someone will likely call him and buy it out from under you (IMG:style_emoticons/default/wink.gif) Thats the old owners info who has passed on |
tmacdonald1 |
Jan 24 2016, 09:01 AM
Thank you all for the great info. It has been a great insight of what to look for
SKL1 |
Jan 24 2016, 11:11 AM
Senior Member Group: Members Posts: 1,602 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest |
If it does have minimal rust, 12K is probaby a good deal. Wonder if dash is cracked under that god awful cover.. and hopefully not too many holes left after removing that rear spoiler!! At least the side markers are already gone!! And it is a side shifter !!
Worth a good look. |
tmacdonald1 |
Jan 24 2016, 11:36 AM
If it does have minimal rust, 12K is probaby a good deal. Wonder if dash is cracked under that god awful cover.. and hopefully not too many holes left after removing that rear spoiler!! At least the side markers are already gone!! And it is a side shifter !! Worth a good look. What is a side shifter |
tmacdonald1 |
Jan 24 2016, 11:42 AM
He said it has 4 wheel disk brake? Is this an upgrade? Also said dash pad has been redone
PanelBilly |
Jan 24 2016, 11:44 AM
914 Guru Group: Members Posts: 5,807 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
If there's very minor rust. 9000 would be my target number
iankarr |
Jan 24 2016, 01:18 PM
Agreed. 9K feels right.
4 wheel disc brakes are standard. check the wikipedia for the 914 and the originality forum on this website for lots of good info. |
Lo-Fi Version | Time is now: 17th May 2024 - 03:15 PM |
