Rear Suspension Parts, Assembly to come soon!\ |
Qarl |
Jun 13 2003, 05:45 PM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
Here is my mostly collected rear suspension setup...
From the top down... 9x16 Fuchs - dual annodized rough and clear Trailing Arm Reinforcement Pieces Mueller's Trailing Arm Needle Bearings (From the Korijo Auction plus the setup for the front A-Arms) Early 911 Hubs and Stub Axles and studs (need to be bead blasted) New annodized lug nuts Bilstein Sports with H&R Springs and Adjustable Perches New Bearings I finally took all the crap out of boxes and decided to start laying out parts by sytem and organize stuff in bins and on tables. Regards, Attached image(s) |
seanery |
Jun 13 2003, 08:35 PM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,846 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
probably need another wheel, huh? (IMG:style_emoticons/default/wacko.gif)
Qarl |
Jun 13 2003, 08:37 PM
Damn it! Forgot to check the box before I threw it out!
Oops! Naw... I've got three more (one more 9 incher and 2 8 inchers. Karl |
seanery |
Jun 13 2003, 08:47 PM
which 8's are they 951 rears? I hope I haven't asked you that before.
Qarl |
Jun 13 2003, 09:02 PM
944 (23.3mm offset) 8x16s
930 (15mm) 9x16s |
seanery |
Jun 13 2003, 09:53 PM
I'm using the same 8's when mine is flared (took em off my 951 and put BoxS wheels on).
TRE makes a 9 that looks like the old 10 and that is going on the rear. |
Brad Roberts |
Jun 14 2003, 12:41 AM
Looking good Karl..
I'm going to use 8's and 9's on the 3.6 car.. and do the wheels EXACTLY the way you did them. This is my favorite look for the Fuchs. I first saw them done this way on a 80's poster with a convertable red slant nose wide body car. I have loved the looks since then. It will really look good against a black car. B |
Qarl |
Jun 14 2003, 07:33 AM
Thanks... I have seen a few pics of some European GTs in Yellow and Red with these wheels... drool!
maf914 |
Jun 14 2003, 08:09 AM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
Karl,
I know this has been discussed in various posts before, but what combination of rear hubs, stub axles, bearings, CV joints, axles, and drive flanges are you using to go to five lugs at the rear? Thanks. Mike |
Gint |
Jun 14 2003, 03:28 PM
Mike Ginter Group: Admin Posts: 16,066 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Karl,
Did you send your wheels to WE and have them done? Or did you buy them direct from them? How much? I'm interested in that finish for my set of 4 6x15's. This post has been edited by Gint: Jun 14 2003, 03:48 PM |
Qarl |
Jun 14 2003, 03:36 PM
I would check with Al Reed (check the Pelican 911 board for his phone number). he can probably do it cheaper than Wheel Enhancement.
I bought my wheels from them, but I think they want $160 or so per wheel for the dual annodized (rough clear) finish. This was for larger 8x16 and 9x16 wheels. It may be less for smaller wheels. But check with Al Reed first... he is much cheaper and does as good if not better work Essentially they annodize the entire wheel in the clear finish, then block off the padles and rims and bead blast the background for a dull (rough) finish. Here is another (generic) shot. Attached image(s) |
Gint |
Thanks
Lo-Fi Version | Time is now: 28th April 2024 - 08:16 PM |
