> Has Anyone Done This?
lsintampa
post Jan 26 2016, 03:32 PM
Post #21
I'm in the middle of rebuilding my dash.
I'm using the following parts (all from 914 rubber - Thanks Mark!)
New top dash.
New top padding and vinyl that goes on the top between the windshield and back of the dash top.
New rubber seal for inside front windshield to dash top.
New dash face metal and vinyl.
I removed the steel dash frame - as it made a lot of sense to me.
It appears I can assemble the whole dash (all the parts above - except the seal that would go on last) onto the steel frame, and then install the whole assembled dash in the car. Then finally install the windshield seal.
AS OPPOSED TO - putting the steel frame back in - then putting the dash on the frame, etc.
Bottom line is putting the dash onto the frame and then into the car - seems to me to be a whole lot easier to do.
Has anyone done it that way?
Thanks,
Len
lsintampa   Has Anyone Done This?   Jan 26 2016, 03:32 PM
r_towle   I do not think it will fit. If it does, please sh...   Jan 26 2016, 04:44 PM
Garold Shaffer   I haven't installed one, but I have parted my ...   Jan 26 2016, 05:05 PM
Chris914n6   It is easier with the top pad attached. The bottom...   Jan 26 2016, 05:40 PM
lsintampa   Well, here's the deal. Both a-pillars off, bo...   Jan 26 2016, 06:36 PM
r_towle   Nice   Jan 26 2016, 06:47 PM
Krieger   What about all the wiring for the gauges? I think...   Jan 27 2016, 12:37 AM
lsintampa   What about all the wiring for the gauges? I thin...   Jan 27 2016, 07:37 AM
Darren C   Yep, As you said you can rebuild the whole dash o...   Jan 27 2016, 02:12 PM
Marktini   This may help?? https://www.youtube.com/watch?v=Q...   Jan 30 2016, 09:22 AM
r_towle   Can the whole dash be pulled out this way? I have ...   Jan 30 2016, 11:11 AM
Darren C   Can the whole dash be pulled out this way? I have...   Jan 30 2016, 11:56 AM
lsintampa   Can the whole dash be pulled out this way? I have...   Jan 30 2016, 12:38 PM
r_towle   Anyone post some pics of the fasteners that hold t...   Jan 30 2016, 01:50 PM
Darren C   To remove the WHOLE dash....There are 4 x M6 nuts ...   Jan 30 2016, 02:24 PM
Travis Neff   I would imagine when these cars were put together ...   Jan 30 2016, 04:04 PM
mepstein   Cool thread. I eventually have to tear apart my da...   Jan 30 2016, 04:19 PM
Rob-O   Probably the most difficult part of this is the he...   Jan 30 2016, 09:52 PM
r_towle   I am really happy to learn this.   Jan 30 2016, 10:42 PM
RobW   Does this make sense to pull the dash and work on ...   Jan 31 2016, 06:55 AM
McMark   Does this make sense to pull the dash and work on...   Jan 31 2016, 08:25 AM
3d914   Len or Darren, did you have to have the windshield...   Jan 31 2016, 05:11 PM
Darren C   You should be able to get the dash out with the wi...   Feb 1 2016, 03:06 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 12:54 PM
