Re-using stock oil pump on a stock-ish rebuild |
saigon71 |
Feb 3 2016, 02:47 PM
Senior Member Group: Members Posts: 1,999 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
Pulled my stock oil pump apart and gave it a close inspection. The internals look great with little discernable wear. The only real wear spot I found were slight marks on the drive tang from the cam gear.
The engine I'm building will be a stock-ish 1971 or 2056 with a stock cam or a cam slightly more aggressive than stock. Stock D-jet FI. No external oil cooler. Any issues re-suing the stock oil pump? |
Lo-Fi Version | Time is now: 19th May 2024 - 06:59 AM |
