WTB: Rear Camber/ Alignment shims |
BigFour1973 |
Feb 3 2016, 05:25 PM
Member Group: Members Posts: 187 Joined: 16-November 14 From: Long Beach Member No.: 18,126 Region Association: Southern California |
As the title states, Im looking to get some camber shims for my rear trailing arms as i am going to be installing a the ground control adjustable coilover kit to some bilsteins in the near future.
Thank you, Corey |
porschetub |
Feb 3 2016, 10:19 PM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
As the title states, Im looking to get some camber shims for my rear trailing arms as i am going to be installing a the ground control adjustable coilover kit to some bilsteins in the near future. Thank you, Corey Best to quote sizes,from memory the are 3 or 4. |
BigFour1973 |
Feb 3 2016, 11:00 PM
As the title states, Im looking to get some camber shims for my rear trailing arms as i am going to be installing a the ground control adjustable coilover kit to some bilsteins in the near future. Thank you, Corey Best to quote sizes,from memory the are 3 or 4. You're right, I believe they are 2,3,4 and 6?mm I'm holding to end up with 4-2mms or 2-4mms |
TheCabinetmaker |
Feb 4 2016, 06:08 AM
I drive my car everyday Group: Members Posts: 8,300 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
I have them.
bdstone914 |
Feb 4 2016, 08:44 AM
bdstone914 Group: Members Posts: 4,515 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I have them too in Riverside. Original are 2, 3 and 4mm. If you needs 6mm shims you have other problems. I get $5 each.
0396 |
Feb 4 2016, 10:49 AM
Advanced Member Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
BigFour1973 |
Feb 4 2016, 03:25 PM
I have them too in Riverside. Original are 2, 3 and 4mm. If you needs 6mm shims you have other problems. I get $5 each. Thank you bruce, I'll keep you in mind. Noel is going to check on some for me this weekend. And if that's not the case I'll take a set from you. The reason I say potentially 6mm is because I intend to lower the car a decent amount and I don't want over 1 degree of negative camber. I hate the way a 914 looks like from the rear with excessive negative camber. |
Lo-Fi Version | Time is now: 7th May 2024 - 04:26 PM |
