questions on cc'ing heads |
type47 |
Mar 19 2005, 04:31 PM
1st) recommend a fluid to use. someone said transmission fluid
2nd) i had to cut my own disk and the fit seems OK, not real tight, about 2mm clearance. do i seal the disk with something to keep the fluid in? i was thinking grease (some easy to clean like synthetic wheel bearing grease) 3rd) do i cc all the chambers and do i deck height all the cylinders? now that i think about it, that's a dumb question, never mind (but i thought it would be good not to erase it for somebodies sake) 4th) what's the tolerance? TIA |
MecGen |
Mar 19 2005, 05:08 PM
8 Easy Steps Group: Members Posts: 848 Joined: 8-January 05 From: Laval, Canada Member No.: 3,421 |
Hi
Any thin oil will work fine
I use white Lithium grease, your disc just needs to seal the head above the cyl mating surface.
Shit I don't remember, adjusting CC always from the smallest to biggest (check spec). cheers Joe (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) |
DNHunt |
Mar 20 2005, 07:41 AM
My heads were within a cc of each other 50.5 to 51.5 from Len Hoffman. Include any valve pockets or dishes in the pistons. Decks were within a couple thousands. Compression ratio varied a little more than a tenth. All of that was signed off on by Jake.
Dave |
IronHillRestorations |
Mar 20 2005, 09:50 AM
I. I. R. C. Group: Members Posts: 6,716 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Vegetable oil is OK to use, and it's less toxic.
Lo-Fi Version | Time is now: 5th May 2024 - 01:51 AM |
