1st) recommend a fluid to use. someone said transmission fluid
2nd) i had to cut my own disk and the fit seems OK, not real tight, about 2mm clearance. do i seal the disk with something to keep the fluid in? i was thinking grease (some easy to clean like synthetic wheel bearing grease)
3rd) do i cc all the chambers and do i deck height all the cylinders? now that i think about it, that's a dumb question, never mind (but i thought it would be good not to erase it for somebodies sake)
4th) what's the tolerance?
TIA
