Powder coating parts |
Amphicar770 |
Feb 17 2016, 07:10 PM
Senior Member Group: Members Posts: 1,188 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region |
Looks great and that is awesome pricing.
I took a bunch of stuff locally that I had mostly blasted myself, this included trailing arms, backing plates, etc. I was very pleased when the bill came in for $145 and it looked great. I then brought a 2nd batch including engine tins, engine mounting bar, etc. I let him blast and coat all of these. Nearly crapped when he sent me an invoice this evening for $500. Lesson learned. Trust no one., even if you dealt with them before. Get a quote up front. |
Amphicar770 |
Feb 17 2016, 07:14 PM
BTW, should you need to remove powder coat ... CRC gasket remover, wait 60 seconds, and wipe with a rag. Gone in a flash.
Puebloswatcop |
Feb 17 2016, 08:04 PM
Senior Member Group: Members Posts: 1,389 Joined: 27-December 14 From: Mineola, Texas Member No.: 18,258 Region Association: Southwest Region |
(IMG:style_emoticons/default/smilie_pokal.gif) Man your parts look awesome. I see several newly cad plated items as well...any referrals for where I can send mine to have them done?
saigon71 |
Feb 22 2016, 05:22 PM
Senior Member Group: Members Posts: 1,998 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
Those parts look great!
I'm about 24 hours into wire-brushing, cleaning, rustproofing and painting all my tin with a rattle can. Would have paid the $250. (IMG:style_emoticons/default/dry.gif) |
mepstein |
Feb 22 2016, 05:58 PM
914-6 GT in waiting Group: Members Posts: 19,245 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I just sent over one of Ben's new aluminum 914-6 oil tanks to get done. They did a nice job on my origional tank so I threw it in while I was taking over a batch of parts for a customer. They know my standing order is always satin black.
jkb944t |
Feb 23 2016, 07:25 AM
Member Group: Members Posts: 464 Joined: 17-January 05 From: Canton, OH Member No.: 3,459 Region Association: None |
My Elephant Racing poly-bronze bushings slide over the powder coating without any problem at all. I just added a thin layer of JB Weld over the powder coating and slide the bushing on while slightly rotating it to distribute the JB Weld. They fit like a glove.
Jeff B |
jkb944t |
Feb 23 2016, 07:28 AM
BTW, should you need to remove powder coat ... CRC gasket remover, wait 60 seconds, and wipe with a rag. Gone in a flash. This is really helpful info and good timing since I found out that there is some powder coating that got into the ball joint bore on my front struts. I was trying to decide how to clean it out but now I have the solution! Jeff B |
db9146 |
Feb 23 2016, 10:32 PM
Senior Member Group: Members Posts: 953 Joined: 21-December 04 From: Atlanta, GA Member No.: 3,315 Region Association: None |
Kypton tape can be used to mask off areas prior to powder coating as it can withstand the oven temps. Comes off easily after the part cools and leaves a nice sharp line.
Boomingbeetle |
Nov 2 2016, 08:06 PM
Member Group: Members Posts: 118 Joined: 1-November 16 From: Orange County Member No.: 20,556 Region Association: Southern California |
You should post the shop so others in SoCal/OC/SD have a good tried-n-true PC source. Bump old thread! (IMG:style_emoticons/default/icon_bump.gif) I am in OC San Clemente and I need a powdercoat source (IMG:style_emoticons/default/evilgrin.gif) Any recommendations? |
Lo-Fi Version | Time is now: 30th April 2024 - 01:16 AM |
